Pumping water versus expulsion
  • Context: Undergrad
  • Thread starter Thread starter bgizzle
    Water
The discussion centers on the energy required to lift water from a tank versus using compressed air to expel it. It is established that lifting 5 meters of water from a cylindrical tank measuring 14 meters tall and 10 meters wide requires 44.3 million joules, calculated using the formula involving density and integrals. The conversation also highlights that while using compressed air may seem to require less energy due to shorter distance traveled, the energy conservation principle indicates that both methods ultimately require similar energy, assuming no inefficiencies. However, real-world applications will incur significant losses when using pressurized air.
  • Understanding of fluid dynamics and hydrostatics
  • Knowledge of energy conservation principles
  • Familiarity with integral calculus for calculating work done
  • Basic concepts of pneumatic systems and their efficiencies
  • Research the principles of fluid dynamics in depth
  • Study pneumatic system design and efficiency losses
  • Learn about energy conservation in closed systems
  • Explore practical applications of compressed air in fluid expulsion
Engineers, physicists, and anyone involved in fluid mechanics or pneumatic system design will benefit from this discussion, particularly those interested in energy efficiency and practical applications of lifting and expelling fluids.
bgizzle
Does it take the same amount of energy to lift water out of a tank as it would to force it out using compressed air? For example if there is a cylindrical tank that is 14 meters tall, 10 meters wide and it is filled with water to a depth of 5 meters I know that it takes 44.3e6 joules to lift that water out of the tank. (9800 n/m^3, 25pi, dy, 14-5... solved using integrals) Is there a formula for how much compressed air it would take to force the water out a vent on the bottom of the tank, assuming the tank is surrounded by water (but attached to the bottom so it wouldn't start floating as you pump in compressed air)?
My thought was it would take less energy to force water out because distance traveled would be less. So if say your tank is 1000 feet down and you wanted to pump the water up and out through a pipe or force it out through a vent, the compressed air way might take less energy. How much force of resistance are you meeting from the water outside the tank?
If the water ends at the same height and if we neglect all inefficiencies, it needs the same amount of energy. This is just energy conservation. In a real setup, that pressurized air will give significant losses.
  • · Replies 26 ·
9K
  • · Replies 32 ·
14K
