Capacitator Circuit and determining unknown charges voltages
  • Thread starter Thread starter liliacam
    Charges Circuit
The discussion revolves around a capacitor circuit involving four capacitors with specified capacitances and an initial charge on one of them. Participants are tasked with determining the charge and voltage across each capacitor and the total voltage across the combination.
  • The original poster attempts to analyze the circuit by applying rules for series and parallel capacitors, questioning the relationships between charges and voltages. Some participants question the configuration of the capacitors, particularly the series and parallel arrangements, and whether the assumptions about charge distribution are correct.
Participants are actively engaging in clarifying the circuit's configuration and the implications of charge conservation. Some guidance has been offered regarding the misunderstanding of series and parallel connections, and attempts to redraw the circuit have been made to aid understanding.
There is mention of confusion due to the circuit diagram, and the original poster notes a lack of formal instruction on redrawing capacitors, which may affect their understanding of the problem.
liliacam
Suppose in the figure (Figure 1), that
C1 = C2 = C3 = 18.0μF and C4 = 28.2μF.
If the charge on C2 is Q2 = 37.4μC, determine the charge on each of the other capacitors
Determine the voltage across each capacitor.
Determine the Voltage Vab across the entire combination.
https://dl.dropbox.com/u/47465778/MP24.24.PNG
[tex]Q=CV[/tex]
Rules for Series:
Q is the same across a series
[tex]\frac{1}{Ceq} = \frac{1}{C1} + \frac{1}{C2} + . . .[/tex]
[tex]Vtotal = V1 + V2 . . .[/tex]
Rules for Parallel:
[tex]Qtotal = Q1 + Q2 . . .[/tex]
[tex]C_(eq) = C1 + C2 . . .[/tex]
V is same across parallel
Let 1 and 2 be in Series. Then Capacitance can be added as reciprocals
[tex]\frac{1}{Ceq} = \frac{1}{18} + \frac{1}{18}[/tex]
[tex]Ceq = 9μF[/tex] for 1 and 2
Q1=Q2...because they are in series, Q is same. Q1 = Q2 = 37.4 μC
[tex]Q = CV.[/tex] So,
[tex]37.4 = 9*V[/tex]
[tex]V = 4.155 V[/tex]
I figured that because Voltage is the same in parallel, then this voltage is the same across the board for 3 and 4. So I found C for 3 and 4
3 and 4 are in series with each other, so
[tex]\frac{1}{Ct} = \frac{1}{18} +\frac{1}{28.2}[/tex]
[tex]Ct = 10.987...[/tex]
Then [tex]Q = CtV[/tex]
[tex]= 10.987*4.155 = 45.65 μC[/tex]
Q3 = Q4 because Q's are equal in series.
Final Answer: Q1=Q2 = 37.4 and Q3 = Q4 = 45.65 all in microColoumbs (Wrong)
Although I'm fairly certain Q1 does equal Q2, but since I have to enter all of the answers at once, if one answer is wrong then the rest is wrong.
Where did I go wrong? Please help, I did my best but I'm pretty shaky on this stuff. Also this is my first time posting so sorry if I did anything weird with the formatting.
welcome to pf!
hi liliacam! welcome to pf! :smile:
no, they're not in series, there's a junction between them!
also, what happens to the electrons that leave the top plate of Q4 ?
they have to spread over the left plates of both Q1 and Q3
so how could they all be on Q3 ? :wink:
Hi! Thanks for responding so quickly
So I tried it again...I guess the diagram confused me. I redrew it here:
https://dl.dropbox.com/u/47465778/MP24Redrawn.PNG
With 3 still in parallel and 1, 2, 4 in series with each other. My current teacher still hasn't taught us how to redraw capacitors but I hope this is on the right track at least. So the electrons from 4 spread over 1 and 2, then 3?
If this drawing is correct, then:
Q1 = Q2 = Q4 = 37.4μC
Q3 = ?
[tex]\frac{1}{Ceq} = \frac{1}{C1} + \frac{1}{C2} + \frac{1}{C4}[/tex]
[tex]\frac{1}{Ceq} = \frac{1}{18} + \frac{1}{18} + \frac{1}{28.2}[/tex]
[tex]Ceq for 1,2,4= 6.822[/tex]
New Capacitance:
Ceq total = Ceq for 1,2,4 + C3
[tex]Ceq total = 6.822 + 18 = 24.822 μF[/tex]
New Voltage:
[tex]Q = CV[/tex]
[tex]Q1 = C1V1[/tex]
[tex]V1 = 2.077 V[/tex]
If 1, 2, 4 is in parallel with 3, then V is the same across
[tex]V3 = 2.077 V[/tex]
[tex]Q total = Ctotal*Vtotal[/tex]
[tex]Qt = 24.822*2.077[/tex]
[tex]Qt = 51.575 μC[/tex]
[tex]Qt = Q3 + Q(1,2,4)[/tex]
[tex]51.574μC = Q3 + 37.4[/tex]
[tex]Q3 = 14.175 μC[/tex]
Final Answers: Q1 = Q2 = Q4 = 37.4, Q3 = 14.75 all μC
Is this correct? I haven't had an official lecture on this yet, so it's just hard for me to visualize what exactly is going on.
Nevermind, figured it out.
  • · Replies 19 ·
