New Reply
Vapor Pressure Question
Share Thread
Feb25-13, 05:15 AM   #1
Hi all,
Just have a quick question regarding the measurement of vapor pressure.
Firstly, let me explain my scenario. I am carrying-out some measurements of steam condensation in a vacuum. The steam is being condensed in a air-cooled heat exchanger.
Initially, I let in a quantity of steam (at atmospheric pressure) into my heat exchager. I then close off the inlet & exit valves to trap a quantity of steam in the heat exchanger (creating a closed system) and commence the air flow. Thus there is a fixed mass of steam in my heat exchanger. The energy from this steam is transferred to the surrounding air flow and eventually, the temperature of the steam (vapor) decreases until it reaches the ambient air temperature. With no air leaks occuring, the pressure I measure also reduces to the saturation pressure for that given ambient temperature.
Firstly, am I right in assuming that at this point I have a vapor-water interface in my heat exchanger, which is in equliibrium (rate of evaporation=rate of condensation) at the given ambient temperature? Once the system has reached steady-state of course?
Secondly, if I recommence the steam flow into the system, I see that the pressure I am measuring increases...why is this? Should the steam entering the system not be under a vacuum and have a temperature and pressure determined by the ambient air temp?
Thanks for any help
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Feb25-13, 09:34 AM   #2
Recognitions:
Homework Helper Homework Help
Multiple posts with the same topic in different forums is discouraged.
Check the General Physics section for my reply.
New Reply
Similar discussions for: Vapor Pressure Question
Thread Forum Replies
Estimating Vapor Pressure and Vapor Mole Fraction Biology, Chemistry & Other Homework 0
Question about mercury's vapor pressure Classical Physics 5
Calculating mass of vapor from vapor pressure Biology, Chemistry & Other Homework 4
Vapor pressure question in chemical thermodynamics Biology, Chemistry & Other Homework 2
vapor pressure question Chemistry 1
