Work Required to Empty Tank of Hot Chocolate
The work required to empty a tank shaped like an inverted right circular cone, with a height of 8 meters and a radius of 6 meters filled with 7 meters of hot chocolate, is calculated using the formula W = ∫ (m * g) * (8 - h) dh. The mass of the hot chocolate is determined to be 54360π kg, and the density is 1510 kg/m³. The correct integral for calculating work is ∫ from 0 to 7 of (54360π * 1510 * (8 - h)) dh, resulting in a total work of approximately 8.229 x 10^6 Joules.
  • Understanding of calculus, specifically integration techniques
  • Knowledge of physics concepts such as mass, density, and work
  • Familiarity with the geometry of cones and volume calculations
  • Basic understanding of gravitational force and its application in physics
  • Study advanced integration techniques in calculus
  • Learn about the principles of fluid mechanics and hydrostatics
  • Explore the applications of density in real-world scenarios
  • Investigate the physics of work and energy in fluid systems
Students in physics or engineering, educators teaching calculus and physics concepts, and professionals involved in fluid dynamics or mechanical engineering.
ProBasket
A tank in the shape of an inverted right circular cone has height 8 meters and radius 6 meters. It is filled with 7 meters of hot chocolate.
Find the work required to empty the tank by pumping the hot chocolate over the top of the tank. Note: the density of hot chocolate is 1510kg/m^3
m = pi*r^2
m = 36*pi*1510
m = 54360*pi
distance = (8-x)
[tex]\int_{0}^{7} 54360*pi*(8-x) dx[/tex]
this is clearly wrong, because i already tried to submit this, but it wouldn't accept it. can someone tell me what I am doing wrong?
From problem statement:
{Height of Liquid Top Surface} = h
{Radius of Liquid Top Surface} = r = (6/8)*h = (3/4)*h
{Volume of Liquid in Tank} = (1/3)*π*r2*h = (1/3)*π{(3/4)*h}2*h = (0.589)*h3
{Mass of Liquid in Tank} = M = {Density}*{Volume of Liquid in Tank} =
= (1510)*(0.589)*h3 = (889.4)*h3
{dM/dh} = (3)*(889.4)*h2 = (2668)*h2
{Work Lifting Liquid Over Tank Top} = W = ∫ g*(8 - h)*(dM/dh)*dh
[tex]\ \ \ \ W = \int_{0}^{7} g(8 - h)(2668)h^{2} \ dh[/tex]
[tex]\ \ \ \ W = (2668)g\int_{0}^{7} (8 - h)h^{2} \ dh[/tex]
[tex]\ \ \ \ W = (26173)\int_{0}^{7} (8h^{2} - h^{3}) \ dh[/tex]
[tex]\ \ \ \ \color{red} W = (26173)(314.4) = (8229000 \ J) = (8.229*10^{6} \ J)[/tex]
Your approach is correct, but there is a mistake in your integration. The correct integral should be:
\int_{0}^{7} 54360*pi*(8-x)*1510 dx
This is because the work required to pump out the hot chocolate is equal to the force (mass * gravity) multiplied by the distance it is pumped (8-x) and the density of the hot chocolate. So the formula should be:
Work = Force * Distance = (m*g) * (8-x) = (m*1510) * (8-x) = (36*pi*1510) * (8-x)
Then you integrate this formula from 0 to 7 (the initial and final heights of the hot chocolate) and you will get the correct answer.
11K
