Finding phi constant based on initial position and initial velocity
The discussion revolves around finding the phase constant (ϕ) in the context of harmonic motion, specifically using the equations for position and velocity. The original poster provides initial conditions for position and velocity and seeks to determine the correct value of ϕ based on these conditions.
  • Participants discuss solving the position and velocity equations for time (t) and how to equate them to find ϕ. There is a mention of the number of equations generated and the implications of the initial conditions provided.
The discussion is ongoing, with participants exploring different methods to approach the problem. Some guidance has been offered regarding setting equations equal to each other to solve for ϕ, but no consensus has been reached on the best method or the correct value of ϕ.
Participants note the initial conditions provided and the potential complexity introduced by the multiple equations derived from the position and velocity functions. There is also a consideration of the implications of ignoring time values in the equations.
InvalidID
[tex]x(t)=Acos(ωt+ϕ)\\ v(t)=-Aωsin(ωt+ϕ)\\ \\ Let\quad n=integer,\quad A=0.5,\quad ω=2.\\ \\ Given\quad initial\quad position\quad (0,\quad 0.25)\quad and\quad initial\quad velocity\quad (0,\quad 1),\quad find\quad ϕ.\\ \\ x(t)=0.5cos(2t+ϕ)\\ 0.25=0.5cos(ϕ)\\ ϕ=±1.0471975512+2πn\\ \\ v(t)=-sin(2t+ϕ)\\ 1=-sin(ϕ)\\ ϕ=-1.5707963268[/tex]
So which one is it? :S
Immediate help is very appreciated!
Solve your position equation for t; utilize x=0. Solve your velocity equation for t; you have two components for the velocity, what is its initial magnitude? After that, you can set both equations equal to one another and solve for phi.
Solving for t yields 4 equations - not 2 (2 equations from position and 2 from velocity).
You are given (x, y)=(0, 0.25). You have an equation for x. Plug in the value for x, then solve for t. You will have an equation that is a function of phi (1 unknown).
You then have an equation for the velocity given as (vx, vy)=(0, 1). Furthermore, you have an equation for the velocity, which would merely be the magnitude of the force vector. You have two components, and hence can determine the magnitude. You can solve this equation for t, which would also be in terms of phi.
Set these two equations equal to one another and you should be able to solve for phi. 2 equations, 1 unknown.
The given is in the form of (t, x) and (t, v).
Okay. What if you ignore the values for t, and solve both of the equations for t. Then use the two to find phi?
  • · Replies 21 ·
  • · Replies 24 ·
