Mechanical engineering project which would help for my MBA?
The discussion emphasizes the importance of practical experience in mechanical engineering before pursuing an MBA. It asserts that an MBA should not be the immediate goal for engineering students, as effective management requires a solid understanding of the technical aspects of projects. Significant projects undertaken during the engineering degree can enhance visibility to business schools. The conversation critiques the notion that management can be effectively learned without prior experience in the relevant field.
  • Understanding of mechanical engineering principles
  • Familiarity with project management concepts
  • Knowledge of the MBA curriculum and its objectives
  • Experience in hands-on engineering practice
  • Research project management methodologies applicable to engineering
  • Explore the role of practical experience in engineering careers
  • Investigate the differences between technical and managerial skills in engineering
  • Learn about the impact of MBA programs on career trajectories in engineering
Mechanical engineering students, aspiring MBA candidates, and professionals considering a transition from engineering to management roles will benefit from this discussion.
rahul wiley
am in 6th semester mechanical engineering please suggest me projects which would help me to get into b-schools.
An MBA is supposed to teach you how to manage people and projects. Engineering is the technical side of a project. The MBA is supposed to set goals, recruit people, estimate budgets, and so forth.
Any project you do of significant size will be noticed by the school.
That said: the MBA is not a goal unto itself. In other words, it is like getting a coaching degree without any background in what sport you are coaching. Can a figure skating coach turn around tomorrow and coach a hockey team? No. And yet there are idiots who walk around saying things such as "a good manager can manage anything" --as if management is an end in and of itself.
It is not.
Do whatever you need to do with a mechanical engineering degree. I also highly recommend getting into the practice of mechanical engineering for a few years. The field of engineering in particular is a blend of the practical hands-on experience with the academic theories and methods. An engineer should have equal parts of both.
THEN and only then, if you feel you want to manage people, should you consider the MBA. Be forewarned, there is a painfully large amount of truth to the Dilbert comic strip, and much of it stems from poorly educated MBA graduates that most schools produce. If you forge ahead to the MBA straight out of engineering school, you will be doing everyone, including yourself, a disservice.
It is not.
Thank you Jake...your post has not only solved my doubt about project but also my doubts about MBA as a whole,Thank you very much
i wish i had a mentor like you...
  • · Replies 44 ·
  • · Replies 19 ·
