Solve Lagrange Multiplier Problem | f(X,Y,Z) = 2XY + 6YZ + 8XZ
The discussion focuses on solving the Lagrange Multiplier problem to minimize the function f(X, Y, Z) = 2XY + 6YZ + 8XZ under the constraint XYZ = 12. Participants share the gradients ∇f = <2Y + 8Z, 2X + 6Z, 6Y + 8X> and ∇g = , emphasizing the importance of understanding the underlying concepts rather than relying solely on calculators like the TI-83 Plus. The solution involves substituting expressions for Y and X in terms of Z into the constraint, leading to equations that can be solved for Z and λ. The final steps include eliminating λ by manipulating the equations to derive relationships between X, Y, and Z.
  • Understanding of Lagrange Multipliers
  • Knowledge of gradient vectors
  • Familiarity with algebraic manipulation of equations
  • Basic calculus concepts
  • Study the method of Lagrange Multipliers in detail
  • Learn how to derive and manipulate gradient vectors
  • Practice solving optimization problems with constraints
  • Explore the use of symbolic computation tools for solving equations
Students in calculus or optimization courses, mathematicians, and anyone interested in applying Lagrange Multipliers to solve constrained optimization problems.
Baumer8993
Minimize f(X, Y, Z) = 2XY + 6YZ + 8XZ subject to the constraint XYZ = 12.
The gradients of the equations, and XYZ = 12.
I have the gradients for both of the equations.
∇f = <2Y + 8Z, 2X + 6Z, 6Y + 8X> ∇g = < YZ, XZ, XY> I also have XYZ 12.
I have set them up in there separate equations with the λ in them. I have just stuck on how to solve them. Isn't there a way to plug the equations in the my TI - 83 Plus to solve them?
No, don't do that; you won't learn anything that way. Use such tools later, to save time, after you have learned the basics.
In this case: use the first equation to solve for Y in terms of Z, use the second equation to solve for X in terms of Z. Now plug those tow expressions into the third equation. This will give you an equation in Z and λ alone. One way to proceed would be to try to solve that equation for Z in terms of λ; there would be more than one solution, corresponding to multiple roots of a higher-order equation. Another way would be to also substitute your expressions for X and Y into the constraint equation, giving a second equation involving z and λ. Now you could try to solve those two equations in the two unknowns in some way.
So you have [tex]2Y+ 8Z= \lambda YZ[/tex], [tex]2X+ 6Z= \lambda XZ[/tex], [tex]6Y+ 8X= \lambda XY, together with XYZ= 12.<br /> <br /> Since a specific value for [tex]\lambda[/tex] is not necessary to solve this problem, it is often simplest to first eliminate [tex]\lambda[/tex] by <b>dividing</b> one equation by another. Here, dividing the first equation by the second, [tex]\frac{2Y+ 8Z}{2X+ 6Z}= \frac{Y}{X}[/tex] which is the same as X(Y+ 4Z)= Y(X+ 3Z) or XY+ 4XZ= XY+ 3YZ which reduces to 4XZ= 3YZ, 4X= 3Y.<br /> <br /> Similarly, dividing the third equation by the second, [tex]\frac{6Y+ 8Z}{2X+ 6Z}= \frac{Y}{Z}[/tex] which is the same as Z(3Y+ 4Z)= Y(X+ 3Z) or [tex]3YZ+ 4Z^2= XY+ 3YZ[/tex] which reduces to [tex]4Z^2= XY[/tex]. <br /> <br /> Since Y= (4/3)X, that last equation becomes [tex]4Z^2= (4/3)X^2[/tex] or [tex]Z^2= 4X^2[/tex] and [tex]Z= \pm 2X[/tex]. Continue from there.<br /> <br /> I agree with Ray Vickson- the last thing you want is to have someone or something do those solutions for you. You need to <b>learn</b> the ideas so that you will understand, when you do use "technology", what is going on.[/tex]
  • · Replies 16 ·
  • · Replies 17 ·
