Adding pipes for compressed air delivery
The discussion centers on the effects of adding additional pipes to a compressed air delivery system, specifically regarding pressure and flow rate. Participants explore the implications of increasing the number of delivery pipes from one to two, considering factors such as system symmetry, demand characteristics, and flow dynamics.
  • Some participants propose that if the system is symmetric, flow will split evenly between the pipes and pressure drop will be reduced.
  • Others argue that the effect on flow and pressure also depends on the specific configuration of the system and the equipment being fed by the pipes.
  • One participant mentions that air behaves like any liquid, flowing from high to low pressure and taking the path of least resistance.
  • A later reply questions whether flow will be halved in each pipe and suggests that pressure in each pipe may be higher than with a single pipe, but acknowledges that the pressure difference will be smaller.
  • Another participant adds that if the piping characteristics are the same, a symmetric system will see symmetric flow, but if the system is asymmetric, flow division will depend on specific conditions.
  • One participant seeks clarification on the relationship between flow velocity and pressure losses, suggesting that adding a pipe may lead to higher pressure in each pipe due to reduced flow velocity.
  • Another participant notes that while pressure at the end may increase if the source pressure remains constant, the exact pressure could vary.
  • It is mentioned that higher air velocity leads to increased friction, which results in a higher pressure drop per length of pipe.
Participants express varying views on the effects of adding pipes, with some agreeing on the potential for symmetric flow in a symmetric system, while others emphasize the complexities introduced by system asymmetries and varying demand conditions. The discussion remains unresolved regarding the exact outcomes of these changes.
Participants highlight limitations in making definitive statements due to the dependence on system symmetry, specific configurations, and varying operational conditions. The discussion reflects a range of assumptions and conditions that affect flow and pressure dynamics.
yun
Hi all! I have a problem here, anyone here knows what will be the effect on pressure and flow rate of compressed air by adding additional pipes leading out from my compressor? For eg. if i were to increase the number of delivery pipes from 1 to 2, will the flow be slpit evenly between the two pipes? And will pressure across each pipe drop too?
WOuld really appreciate any ideas, opinions i can get!
Thank you!
It depends on the whole setup. If it is symmetric with respect to the pipes, flow will be split evenly and pressure drop in the pipes will be reduced.
It also depends significantly on where those pipes are going (i.e. what equipment are they feeding? Is the demand continuous?)
Hi travis, the pipes lead to a diffuser about 6m deep. It is for aeration purposes. Demand wise, sometimes demand is long and continuous (4hrs or longer), at other times it is short and intermittent (10mins on, 10mins off etc.).
There aren't really rules of thumb for how additional lines will affect your system beyond what's been said. If you want to understand how the system will be affected, you'll need to complete an analysis of the flows and pressures based on various operating conditions. (max, nominal, and min loads, different set points, whatever you want to see).
Air is like any other liquid. It flows from high pressure to low pressure and will take the the path of least resistance.
Hi mfb, apologies, i didnt post my reply to you. Thanks for your reply anyway! Can i clarify please, am i right to say that from what you stated, assuming that the system is symmetrical, flow will be halved such that each pipe will have equal flow and pressure in each pipe will be higher than when there was only one pipe?
Thank you!
If the system is symmetric, flow cannot be asymmetric (unless the symmetry is an unstable state, but I would not expect this), right.
The pressure difference will be smaller.
To add to what mfb is saying:
If the piping characteristics, fittings, valves, and end loads of the system are the same, then a symmetrically designed piping system will see symmetric flow.
As mfb said, the pressure difference will be smaller. That is, if you keep the same flow into the entire system such that pipe 1's flow is halved and pipe 2's flow equals that of pipe 1, the air will experience less pressure losses due to the flow velocity (friction).
As I noted, though, if the system is otherwise asymmetric, then how the flow will divide will depend on the specific conditions of each leg of the system.
mfb and travis, thanks for the clarification. indeed, it is not quite possible to make the system symmetric. However, assuming that it is, say that i have pipe a compressor initially delivering compressed air at 6 bar, with only one pipe, the pressure in the pipe may only be 5 bar due to pressure losses. However, if i add an additional pipe, each pipe may have 5.5 bar due to less flow velocity?
The pressure at the end will increase, if the pressure at the source (and the total flow) stays the same. It might be 5.5 bar, but it could be something else, too.
dear mfb and travis, thanks for your replies! If possible, do yall mind elaborating more on why the above is so? Otherwise, you have already been very helpful :)
A higher velocity of the air leads to more friction, which requires a higher pressure drop per length.
