Common temperature for thermal equilibrium
The discussion focuses on calculating the common temperature of two moles of copper in thermal contact, one at 0°C and the other at 100°C, within an adiabatic enclosure at 1 atm pressure. The heat capacity of solid copper is defined by the equation Cp = 33.64 + 6.28x10^-3*T J/mol*K. The correct approach involves using the enthalpy change equations, where ΔH for the combined system equals zero, leading to the integral equations ∫273Tfcp*dT + ∫373Tfcp*dT = 0. This confirms that the heat lost by the hotter copper equals the heat gained by the cooler copper.
  • Understanding of thermodynamics principles, specifically enthalpy and heat capacity.
  • Familiarity with the concept of thermal equilibrium in adiabatic systems.
  • Knowledge of integral calculus for evaluating heat capacity equations.
  • Basic principles of heat transfer and energy conservation.
  • Study the derivation of the heat capacity equation for solid materials, particularly copper.
  • Learn about the principles of adiabatic processes in thermodynamics.
  • Explore the concept of thermal equilibrium and its mathematical representation.
  • Investigate the application of integral calculus in thermodynamic calculations.
Students studying thermodynamics, physics enthusiasts, and professionals in materials science or engineering who require a deeper understanding of heat transfer and thermal equilibrium principles.
Cisneros778
One mole of copper at a uniform temp. of 0 Celsius is placed in thermal contact with a second mole of copper which, initially, is at a uniform temperature of 100 Celsius. The pressure in the system is maintained at 1 atm. The two moles of copper are thermally insulated from the surroundings. Temperature dependence of the constant pressure heat capacity of solid copper can be described by:
a) Calculate the common temperature of the 2 mole system, which is contained in an adiabatic enclosure, when thermal equilibrium is attained.
2. Homework Equations
dH = cp*dt
dS = dq/T
Since it is in an adiabatic enclosure, dq = 0.
ΔH= H2 - H1 = dq = 0
but in the solution, it says ΔH = H1 + H2 = 0
273Tfcp*dT = - ∫373Tfcp*dT
I don't understand why this approach is correct.
dH = cp*dt
dS = dq/T
For the combined system of two moles,
ΔH=∫273Tfcp*dT +∫373Tfcp*dT=0
where the first term represents the change in enthalpy of the mole initially at 0 C, and the second term represents the change in enthalpy of the mole initially at 100 C.
  • · Replies 23 ·
11K
  • · Replies 16 ·
  • · Replies 16 ·
40K
