| New Reply |
Starting torque advice |
Share Thread | Thread Tools |
| Mar8-13, 10:02 AM | #1 |
Hi Guys,
Could you advice on the minimum starting torque of the motor? Moment of Inertia of the 1200mm dia cylinder is 52.5 Kg m^2 The cylinder is run by wheel that has 38mm diameter and runs at 230RMP Thanks |
| Mar8-13, 02:13 PM | #2 |
Is the cylinder attached to the wheel? In that case, it's the two moments of inertia added together. If one is driving the other (i.e. the wheel-cylinder interaction is like a gear system), it gets a bit more complicated, and since it's been a while since I had to do a system dynamics problem, I can't give an exact answer.
| New Reply |
| Thread Tools | |
Similar Threads for: Starting torque advice
| Starting My Physics BA (BS?), Need Some Advice | Career Guidance | 3 | ||
| Advice for starting out in research | Academic Guidance | 1 | ||
| Motor Torque, Starting Torque, Stall Torque, Load Torque | Mechanical Engineering | 3 | ||
| Need some advice on starting a blog | Computers | 4 | ||
| Advice of path to a PhD -starting from irrelevant BA | Academic Guidance | 1 | ||
