Physics momentum problem: units
The discussion revolves around physics problems involving momentum and energy conservation, specifically focusing on unit conversions and the application of physical principles in problem-solving scenarios.
  • Mixed
  • Participants explore the calculation of sliding distance after a collision, questioning unit conversions from meters to centimeters.
  • There is a discussion about the application of conservation of energy in a separate problem involving a girl on a trampoline, with participants questioning the validity of their equations and unit consistency.
  • Some participants express uncertainty about assumptions and the implications of unit discrepancies in their calculations.
The conversation includes attempts to clarify unit conversions and the correct application of physics principles. Some participants have provided guidance on unit conversions and the structure of energy equations, while others are still grappling with their calculations and seeking further clarification.
Participants are working under the constraints of homework assignments, which may limit the information available and the assumptions they can make. There is a focus on ensuring that units are consistent throughout the calculations.
oldunion
physics momentum problems
Fred (mass 70.0kg) is running with the football at a speed of 4.70m/s when he is met head-on by Brutus (mass 130kg), who is moving at 8.10m/s. Brutus grabs Fred in a tight grip, and they fall to the ground. How far do they slide?
Part A
The coefficient of kinetic friction between football uniforms and Astroturf is 0.290.
Give answer in cm
I got an answerof 13.1m/s=5.684m/s^2(deltaX) so ultimately deltaX=2.3 but what? meters? and could someone remind me of how to go from m to cm again.
Part A
Give answer in cm
to go from metres to centimetres you multiply by 100
since your WHOLE CALCULATION is in metres what do you think the final answer will come out.
well i know it should be meters, but assumptions always get you lost in some corner of physics you don't want to find yourself in. And since i can't find out how to get to meters, i asked here.
Also, another problem is saying 9.8 meters per second per second. this is 9.8m/s^2, correct?
same problem as the 9.8 question: if i have 39.2m^2/s^2+64m/s is the result 103.2m/s?
No. It's a nonsense expression. You've made a mistake in your original question as well, if [itex]\Delta x[/tex] should be a distance (the mistake could just be keeping track of units wrong, of course).<br /> <br /> If you're <i>ever</i> doing a physics problem and the units don't work out, it means you've made a mistake.[/itex]
A girl of mass 60 kilograms springs from a trampoline with an initial upward velocity of 8 meters per second. At height 2 meters above the trampoline, the girl grabs a box of mass 15 kilograms.
For this problem, use 9.8 meters per second per second for the magnitude of the acceleration due to gravity.
What is the speed of the girl immediately before she grabs the box?
Express your answer numerically, to two significant figures.
i did 1/2Vf^2+60kg(9.8m/s^2)(2m)=1/2(8m/s)^2 I got this down to Vf^2+588J=16m/s
the units don't jive if they want the answer in m/s
I have absolutely no idea where you get
[tex]\frac{1}{2}v_f^2 + mgh = \frac{1}{2}v_i^2[/tex]
from. Do you perhaps mean to use conservation of energy? In that case, your expression should be in the form
[tex] \frac{1}{2}mv_f^2 + mgh = \frac{1}{2}mv_i^2[/tex]
in which case you will find the units work out perfectly.
i canceled the masses initially, why couldn't you do this?
[tex]\frac{1}{2}mv_f^2 + mgh = \frac{1}{2}mv_i^2 \Longrightarrow \frac{1}{2}v_f^2 + gh = \frac{1}{2}v_i^2[/tex]
the units will still work fine, of course (how could dividing both sides of an equation with balanced units by the same quantity affect the balance, anyways?).
i find myself in the same place again. vf^2+ 39.2m^2/s^2=64m/s
[tex]\frac{1}{2}v_f^2 + gh = \frac{1}{2}v_i^2[/tex]
[tex]\Longrightarrow v_f^2 + 2\left(9.8\frac{\mbox{m}}{\mbox{s}^2}\right)(2\mbox{m}) = \left(8\frac{\mbox{m}}{\mbox{s}}\right)^2[/tex]
[tex]\Longrightarrow v_f^2 = 64\frac{\mbox{m}^2}{\mbox{s}^2} - 39.2\frac{\mbox{m}^2}{\mbox{s}^2} = 24.8 \frac{\mbox{m}^2}{\mbox{s}^2}[/tex]
[tex]\Longrightarrow v_f \approx 5 \frac{\mbox{m}}{\mbox{s}}[/tex]
And if you didn't notice, your only error in your last calculation was not realising that [tex]\left(\frac{\mbox{m}}{\mbox{s}}\right)^2 = \frac{\mbox{m}^2}{\mbox{s}^2}[/tex].
same question, what is maximum height of the girl to two decimal places.
1/2*75kg(4m/s)^2+75kg(9.8m/s^2)Ymax=1/2(60kg)(8m/s)^2+60kg*9.8m/s^2(2m)
got answer of 3.395, i submitted answer of 3.40 which is incorrect.
Anyone?
anyone know an answer?
9K
12K
