Meaning of Square of four vector potential
The square of the four vector potential, expressed as (\phi,A)^2=\phi ^2 - A^2, is a Lorentz invariant that has distinct physical interpretations based on its timelike or spacelike nature. When the invariant is timelike, it corresponds to the scalar potential in a frame where the vector position is zero. Conversely, if the invariant is spacelike, it represents the magnitude of the vector potential in a frame where the scalar potential is zero. The interpretation of this invariant can become complex unless the Lorentz gauge is employed, as gauge conditions are frame-dependent.
  • Understanding of four vector potential in electromagnetism
  • Familiarity with Lorentz invariance and its implications
  • Knowledge of gauge theories, specifically Lorentz gauge
  • Basic concepts of scalar and vector potentials in physics
  • Research the implications of Lorentz invariance in electromagnetism
  • Study the properties and applications of the Lorentz gauge
  • Explore the relationship between scalar and vector potentials in different frames
  • Investigate the role of gauge transformations in field theories
Physicists, particularly those specializing in electromagnetism and field theories, as well as students seeking to deepen their understanding of gauge invariance and the four vector potential.
merrypark3
The square of the four vector potential.
[itex](\phi,A)^2=\phi ^2 - A^2[/itex]
What's the physical meaning of this lorentz invariant?
If the invariant is timelike then it would be the scalar potential in a frame where the vector position was 0, and if the invariant is spacelike then it would be the magnitude of the vector potential in a frame where the scalar potential is 0. However, unless you are using the Lorentz gauge your gauge condition is frame variant so interpreting it becomes a little strange.
hi merrypark3! :smile:
you can add any constant vector to the potential without changing the physics …
so you can make that invariant anything you like! :wink:
  • · Replies 33 ·
