Point Charge in an uncharged spherical conductor
The discussion revolves around determining the electric field of a point charge surrounded by a hollow uncharged metal sphere using Gauss's Law. The problem is segmented into three regions: inside the sphere, within the conductor, and outside the sphere.
  • Participants explore the implications of Gauss's Law in different regions, questioning the behavior of the electric field inside and outside the conductor.
  • Some participants express uncertainty about the electric field in the hollow region and whether it can be zero.
  • Questions arise regarding the precise location of the point charge and its relationship to the conductor's geometry.
  • There is discussion about the effect of the charge on the distribution of electrons within the conductor.
The conversation is ongoing, with participants sharing their thoughts and questioning assumptions. Some guidance has been offered regarding the behavior of the electric field in the conductor and the implications of Gauss's Law, but no consensus has been reached on the specific values of the electric field in the different regions.
Participants are operating under the constraints of a homework assignment, which may limit the depth of exploration. There is a focus on understanding the implications of the conductor's properties and the behavior of electric fields in various regions.
SauerKrauter
Consider a point charge q > 0 which is surrounded by a hollow metal sphere (uncharged) with inner radius R1 and outer radius R2. Use Gauss Law to determine the electric field E=E(r)er in the following regions:
(i) 0 < r < R1
(ii) R1 < r < R2
(iii) r > R2
∫EdA = Q/ε
(i) I believe the answer would be 0 because the electric field inside of an enclosed conductor is always zero
(ii) This is where my troubles really lie, don't know what to do here
(iii) I think that the electric field would be equatable to that of one where the point charge didn't exist outside the conductor as long as r is great enough, and i can solve for this
(i) 0 < r < R1
(ii) R1 < r < R2
(iii) r > R2
∫EdA = Q/ε
What is the precise location of the charge in the hollow of the sphere?
Is it at the center of the hollow?
Is the center of the hollow coincident with the center of the sphere?​
For items (i) & (ii):
The electric field in the conducting material itself is zero. (This is useful for (ii) but not for (i). )
Nothing says that the electric field must be zero In the hollow of a conductor. Gauss's Law confirms this.​
(i) 0 < r < R1
(ii) R1 < r < R2
(iii) r > R2
∫EdA = Q/ε
Not if there is charge inside it!
Can there be an E field in a conductor?
I don't understand this statement.
yes everything is concentric, and I'm starting to see my erroneous thoughts.
(i) would just be the field as if no conductor was present yes? because I am checking the field at which it hasn't reached the conductor
(ii) would be zero because it is inside of the conductor which means the net electric field is zero
(iii) i am now not sure on, but think that it may be the same answer as (i) because the charge (lets say positive) in the conductor would pull all the electrons to the inside, leaving the outside of the conductor positively charged just like it would be before. Is this correct in theory?
Pretty much correct.
In (iii), it's not true that all the electrons are pulled to the inside. Gauss's Law tells us that just enough electrons are pulled to the inside so that the flux in the conducting material is zero. ...
  • · Replies 19 ·
  • · Replies 22 ·
