How Do You Calculate the Average Value of a Function Between Two Points?
  • Context: Undergrad
  • Thread starter Thread starter ribod
    Average Function
The discussion centers around calculating the average value of a function, specifically the function y = x/(x - 1/x), between two specified points on the x-axis. Participants explore mathematical methods to achieve this, including integration techniques.
  • Mathematical reasoning, Technical explanation, Homework-related
  • One participant presents the function and asks for a method to calculate its average value between two points.
  • Another participant suggests using the formula for the average value of a function, involving an integral over the specified interval.
  • A subsequent reply proposes a simplification of the integral result, suggesting it can be expressed in terms of hyperbolic tangent functions.
  • Another participant humorously questions the assumption that the original poster (OP) would be familiar with hyperbolic functions.
  • The OP confirms knowledge of the hyperbolic tangent function but admits to not knowing how to find the average of a function.
  • A later reply reiterates the formula for the average value of a function, emphasizing the integral approach.
Participants generally agree on the mathematical approach to calculating the average value of a function through integration, but there is no consensus on the simplification of the integral or the familiarity with hyperbolic functions.
Some assumptions about the OP's knowledge of mathematical concepts, such as hyperbolic functions, are present, which may affect the clarity of the discussion. The simplification of the integral remains unresolved, and the discussion does not clarify the conditions under which the proposed simplifications hold.
ribod
I have this function:
y=x/(x-1/x)
and I want to find out the average value of y, between two values of x.
Is there some mathematical way to do this?
[tex]\frac{1}{x_{2}-x_{1}} \int_{x_{1}}^{x_{2}} {\frac{x}{x-\frac{1}{x}} dx }[/tex]
[tex]a = x_{1}, b = x_{2}[/tex]
[tex]\frac{1}{b-a} * ( b + \frac{1}{2}*log(b - 1) - \frac{1}{2}*log(b+1) - a - \frac{1}{2} * log(a-1) + \frac{1}{2} * log(a+1) )[/tex]
Correct me if I am wrong but I think that nicely cancels down to:
[tex]\frac{1}{b - a}\left(b - a + \text{tanh}^{-1}(a) - \text{tanh}^{-1}(b) \right)[/tex]
And you assume that if OP doesn't know the avg of a function, then he'll know what hyperbolic tangent is :smile:
I know what tanh is but not the average of a function.
Ah, but do you know what [tex]\tanh^{-1}[/tex] is??
The average of a function, f(x), between x= x1 and x= x2 is:
[tex]\frac{1}{x_2-x_1}\int_{x_1}^{x_2}f(x)dx[/tex]
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 26 ·
