Calculating Speed of a Block Pushed Across a Horizontal Surface
  • Thread starter Thread starter crimpedupcan
    Block Speed
The problem involves calculating the speed of a block being pushed across a horizontal surface with a varying coefficient of kinetic friction. The block starts at rest and is subjected to a constant force while the friction decreases linearly to zero as it moves to a specified position.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the net force acting on the block and how to express acceleration in terms of position. There are suggestions to explore the relationship between force and kinetic energy, as well as to consider differential equations for motion.
The discussion has progressed with participants providing feedback on each other's attempts. Some guidance has been offered regarding the use of kinetic energy concepts and differential equations, though no consensus on a single method has been reached.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is a focus on ensuring the accuracy of the expressions derived for forces and accelerations.
crimpedupcan
A block of mass [itex]m[/itex] is at rest at the origin at [itex]t=0[/itex]. It is pushed with constant force [itex]F_0[/itex] from [itex]x=0[/itex] to [itex]x=L[/itex] across a horizontal surface whose coefficient of kinetic friction is [itex]\mu_k=\mu_0(1-x/L)[/itex]. That is, the coefficient of friction decreases from [itex]\mu_0[/itex] at [itex]x=0[/itex] to zero at [itex]x=L[/itex].
Find an expression for the block's speed as it reaches position [itex]L[/itex].
I ended up with [itex]F_{net}=F_0 - mg\mu_0 + \frac{mgx}{L}[/itex]
I can use this to find [itex]a[/itex] in terms of [itex]x[/itex], but I don't know what use that would be.
That is almost correct. The last term is not quite right. Try checking it, I think you just made a slight mistake. Also, about what to do next - you have an equation for the force on the block, so how could you find the change in kinetic energy of the block?
Try writing
$$ a(x)=\frac{d^2 x}{dt^2} $$
and solve the differential equation for ##x(t)##... then final speed is
$$ \frac{dx}{dt}|_{x=L} $$
Okay, I've solved the problem using the work/kinetic energy method implied by BruceW. Thanks!
If you're curious I got [itex]v=\sqrt{\frac{2F_0L}{m}-Lg\mu_0}[/itex]
yep. nice work!
  • · Replies 33 ·
  • · Replies 16 ·
13K
