Register to reply
Water Driven Propellor
by hwall95
Tags: driven, propellor, water
Share this thread:
hwall95
#1
Mar19-13, 07:15 AM
P: 16
Hey everyone,
For my engineering project Im designing a Flood Resistant Terminal and just wondering if you guys reckon it would be possible to create a propellor that creates thrust to minimise the force exerted on the pontoon by the water. The only way I could think to be able to create it would be channel the water to create a rotational force which is more likely to cause more trouble then it's worth. However if anyone has and thoughts on the matter it'd be greatly appreciated.
Thanks, Harry
Phys.Org News Partner Engineering news on Phys.org
Researchers find security flaws in backscatter X-ray scanners
Virtual reality guides those whose memory is failing
Intelligent navigation system to personalise shopping trips
A.T.
#2
Mar19-13, 08:26 AM
P: 4,017
Quote Quote by hwall95 View Post
What do you mean? Horizontal forces due to waves?
hwall95
#3
Mar19-13, 09:01 AM
P: 16
Well during a flood event the river in which the pontoon is being designed for, reches velocities between 2.5-3.5 m/s, so if horizontal is parallel to the riverbank then yes but not really waves, more the water body itself travelling down the river
Travis_King
#4
Mar19-13, 10:29 AM
P: 840
Forces: equal and opposite.
If you don't want the water to exert a force on your pontoon, then you've got to let it flow with the current. Unless you meant that you would build a free standing struction apart from the pontoon which would help deflect or redirect or whatever some of the water...
hwall95
#5
Mar19-13, 05:44 PM
P: 16
Okay sorry I didn't explain the no force part well, when the pontoon is getting pushed by the floodwaters, tremendous pressure is forced against its pilings which stop any horizontal motion, however if you were to put a motor on the back it could counter some of that force to release stress fractures that may occur over time. Therefore my question was about the feasibility of design a propellor that is rotated by the water to create a thrust that lessens the force acting upon the pilings. The same way if you back of a small fan in will start turning...
johnbbahm
#6
Mar20-13, 10:42 AM
P: 143
I am going to say there is no free lunch, any additional drag is additional drag.
A breakwater would move the force of the water elsewhere, and maybe set up
some eddies.
http://1.bp.blogspot.com/-puvNOk3gjt...0/IMG_1637.JPG
Protecting something from the energy in flood waters goes way back.
Register to reply
Related Discussions
Force of a propellor in fluid Engineering, Comp Sci, & Technology Homework 0
Setup of a differential element on a propellor blade Introductory Physics Homework 4
Plane's Propellor Illusion General Physics 0
Calculating Gyration forces on a propellor shaft Mechanical Engineering 1
Propellor Thrust General Physics 30
