Finding limits in 3D. How do you know on what line to approach?
The discussion revolves around understanding how to determine the limit of a function as it approaches a point in 3D space, particularly focusing on the choice of paths or lines along which to approach that point. Participants explore the implications of different approaches and the reasoning behind selecting specific paths, including straight lines and curves.
  • One participant expresses confusion about how to determine which lines to approach when evaluating limits of functions as (x, y) approaches (0, 0).
  • Another participant argues that testing along various lines is not sufficient to prove the existence of a limit, emphasizing the need to apply the full definition of limits in multiple dimensions.
  • A different viewpoint suggests that while many functions may yield the same limit along straight lines, they can still fail to have a limit when approached along curves.
  • One participant questions the arbitrary nature of substituting specific functions like y = x^2 in textbooks, seeking clarity on the reasoning behind such choices.
  • Another participant provides an example involving the function (xy^2)/(x^2 + y^4) to illustrate that a constant limit along straight lines does not guarantee the existence of a limit, citing counterexamples from parabolic curves.
  • There is a discussion about the design of functions to demonstrate different limits along various paths, with one participant providing a specific function that behaves differently along certain curves compared to straight lines.
  • A question is raised about the applicability of polar coordinates for limits not approaching (0, 0), specifically when approaching (1, 0).
  • Another participant suggests shifting the function to center it at (0, 0) before applying polar coordinates, indicating a method for evaluating limits at different points.
Participants express differing opinions on the necessity and sufficiency of testing limits along various paths. There is no consensus on the best approach to determining limits in 3D, and multiple competing views remain regarding the reasoning behind selecting specific paths.
Participants highlight the limitations of relying solely on straight-line approaches and the potential for functions to exhibit different behaviors along curves. The discussion also touches on the design of functions to illustrate specific limit behaviors, indicating that the choice of paths can be influenced by the function's characteristics.
mrcleanhands
So say I have an arbitrary function and I want to know it's limit as x,y approaches 0.
I could test what happens when the x-axis approaches 0, y-axis as it approaches 0 but there are some functions where I'm told that I also need to test what happens when y=mx approaches 0, and then y=x^2 and x=y^2 and I'm quite confused as to how we know what lines to approach 0 on and what functions those lines are in 3D and how ones works that out. I've basically lost any form of intuition here.
Those are only pathological examples of various ways that a function can fail to have a limit at a point, so that one doesn't labor under the false impression that one need only test along all lines, or a selection of curves through the point in question. Ie., they tell you why you should not take the approaches in question at face value. You must apply the full definition of the limit in more than one dimension to prove that a given function f(x, y) has a limit L at a point (a, b) and show that all the values of f in a disk of radius ε about (a, b) approach L as ε approaches 0. You cannot take a shortcut and simply write y as a function of x for any arbitrary function unless you show some other reason why this technique will give the correct limit L.
I would not call them "pathological". In a very specific sense "almost all" function will give the same limit along all straight lines but NOT have a limit, since you can get different results by approaching a point along a curve.
Perhaps the simples thing to do in three dimensions (or two dimensions) is to change to spherical (polar) coordinates so that as long as the limit as [itex]\rho[/itex] (r) goes to 0 exists, independent of the other coordinates, the limit will exist.
I just mean it seemed arbitrary to me that they would substitute in these random functions in the textbook and I was trying to understand what the reasoning was behind deciding to substitute in something like y=x^2...
I really like this idea, that going along a curve gives you a different limit
The one we always were taught was (xy^2)/(x^2 + y^4), the contour plot:
http://www5a.wolframalpha.com/Calculate/MSP/MSP46721d7g190ff4673c600001df0fie0bd6g5dbg?MSPStoreType=image/gif&s=19&w=299.&h=300.&cdf=RangeControl
The limit at the origin is 0 along any straight line, yet there are two contours x = y^2 and x = -y^2 which are 1/2 and -1/2 everywhere, including through the origin!
This is a way of demonstrating that a constant limit along every straight line is not sufficient to prove the limit exists. The parabolic curves are counterexamples that are sufficient to prove that the limit doesn't exist, so that's why they're picked. In the above example, rather than being randomly chosen, these parabolas are fairly evident from the contour plot.
They designed the function to have a particular limit at that point that was different from limits along straight lines through the point in order to illustrate the fact that you shouldn't assume taking the limit along all straight lines through the point would give you the correct limit. It was arbitrary; they could have designed their function to behave in many other ways to illustrate the same point with a different curve.
For example, here's a designer function where the design is much more obvious:
[tex] f(x, y) = \begin{cases}1, & y = e^x\\ 0, & y \neq e^x\end{cases}[/tex]
If we attempt to approach the point (0, 1) along any straight line or polynomial curve, we get 0 as the limit of f, but approaching along [itex]y = e^x[/itex] gives a different limit, and thus the limit of f at (0, 1) does not exist. There are many ways to hide this behavior so that it is not as obvious which curves will give different limits, and thus help caution the student about limits that may seem obvious.
Is it possible to use polar co-ordinates to test for limits when your not checking the limit as f approaches (0,0), e.g. we want to see the limit as f approaches (1,0)
I'd have thought you can shift the function to (0,0) by replacing x with x-1, and then convert to polars.
eg.
lim(f(x,y)) at (1,0) = lim(f(x-1,y) at (0,0)
