Magnetic field at the edges of a current-carrying wire
The magnetic field at the edges of a long current-carrying wire differs from that in the middle, as established by the Biot-Savart law. The formula for calculating the magnetic field at a point P outside the wire is B = μ₀I/(4πa) [cos θ₂ - cos θ₁]. For points near the middle of the wire, the magnetic field is B = μ₀I/(2πa), while at the left end, it is B = μ₀I/(4πa). The wire must be part of a circuit to maintain a steady current, as free ends cannot exist in practice.
  • Understanding of Biot-Savart law
  • Familiarity with magnetic field calculations
  • Knowledge of current-carrying conductors
  • Basic circuit theory
  • Study the Biot-Savart law in detail
  • Learn about magnetic field calculations for different geometries
  • Explore circuit design principles for current-carrying wires
  • Investigate the effects of wire length on magnetic fields
Physicists, electrical engineers, and students studying electromagnetism who seek to understand the behavior of magnetic fields around current-carrying conductors.
Nikitin
At the edges of a very long current-carrying wire, the magnetic field is not the same as in the middle, right?
And integrating biot-savart's law in the edge-region of the wire will make it possible to calculate this field-strength, right?
Yes. If you're interested in the field at a point P, which may be anywhere outside the wire, the B-S rule gives you the field at P due to each current element. You integrate these field contributions from the whole wire. This gives you (see thumbnail for meaning of symbols):
[tex]B = \frac{\mu_0 I}{4\pi a} [cos \theta_2 - cos \theta_1][/tex].
This covers the cases you're interested in; it's very general.
For a very long wire, if P is outside the wire, near the middle of the wire, then [itex]\theta_2 = 0[/itex], [itex]\theta_1 = \pi[/itex], so [itex]B = \frac{\mu_0 I}{2\pi a}[/itex], whereas if you're outside the wire, at the (left hand) end of the wire, [itex]\theta_2 = 0[/itex], [itex]\theta_1 = \frac{\pi}{2}[/itex], so [itex]B = \frac{\mu_0 I}{4\pi a}[/itex]. If you think about it, you would indeed expect the field to be half as much in the second case as in the first - if you appreciate that the exact length of the wire is immaterial in these 'long wire' examples, because the field from distant parts of the wire is negligible.
Remember that you can't, in practice, have a wire which carries a steady current and which has two free (unconnected) ends. The wire needs to be part of a circuit. For the second case above, the left hand end of the wire would have to be connected to the rest of a circuit by another wire. If this other wire went in the direction directly away from P it wouldn't contribute to the field at P. Can the rest of the circuit (apart from the straight wire) be made so as not to contribute to the field at P?
thanks!
  • · Replies 22 ·
  • · Replies 198 ·
17K
  • · Replies 27 ·
