Rotational motion problem, half solved, can't figure out other half.
The discussion centers on solving a rotational motion problem involving a ceiling fan with 80 cm-diameter blades rotating at 60 RPM. The user successfully calculated the rotational acceleration and the speed of the blade tip 10 seconds after the fan was turned off, arriving at a speed of 1.5 m/s. The user initially struggled with calculating the distance traveled during the fan's coast to a stop but ultimately corrected their approach by using the correct radius in the displacement equation.
  • Understanding of rotational motion concepts
  • Familiarity with kinematic equations
  • Ability to convert RPM to linear speed
  • Knowledge of basic geometry for calculating circumference
  • Study the principles of rotational dynamics
  • Learn how to apply kinematic equations in rotational motion
  • Explore the conversion between RPM and linear velocity
  • Practice problems involving angular displacement and acceleration
Students studying physics, particularly those focusing on rotational motion, as well as educators looking for practical examples of kinematic equations in action.
Vagabond7
Edit: Nevermind, solved it.
A ceiling fan with 80 cm-diameter blades is turning at 60rpm . Suppose the fan coasts to a stop 25 s after being turned off.
What is the speed of the tip of the blade 10 seconds after being turned off?
Through how many revolutions does the fan turn while stopping?
It's just kinematic stuff, just rotational, no particularly complex equations.
Ok, so the first part I could solve just fine.
I solved for the rotational acceleration using Vf=Vi+at where Vf=0, Vi=pi*.8=2.51 m/s(thanks to the easy conversion of 60rpm to m/s) and t=25s. The acceleration was -.1004. Then I just replugged the values in and solved for Vf at 10 seconds getting 1.5 m/s. That went fine, it was the correct answer.
The second part is where I am getting trouble. I figured I could just use a general kinematic displacement equation like df=di+vt+.5at^2 to get the distance traveled and then just divide by the circumference...which now that I am typing, I am realizing I put the wrong thing in my calculator, and I just solved it. Lolz. I divided by 2*pi*.8, but .8 is the diameter not the radius. pi*.8 gets me the right answer.
*sigh,* don't you hate it when you get caught up, not by a lack of understanding, but by just dumb errors? Well thanks for the speedy replies I know I would've gotten. I'll probably be back for more help later.
Well done - at least you didn't just delete the question or leave the actual soution off.
This way, it is possible someone else will be able to use what you did as an example.
  • · Replies 19 ·
