Spring Constants, Work, and Force
The problem involves a scenario where a skateboarder uses a spring to launch off a ramp, with specific parameters including mass, spring constant, ramp angle, and length. The questions focus on whether the skateboarder will clear the ramp, the maximum height achieved, and the speed upon entering the ramp, while applying principles of energy conservation.
  • Participants discuss the relationship between the height achieved and the ramp's height to determine if the skateboarder will clear the ramp. There is also confusion regarding the terminology used in the problem, particularly what "it" refers to in the context of speed.
Some participants have provided insights into the relationships between the questions, particularly linking the height achieved to the ramp's height. However, there is still uncertainty regarding the interpretation of the questions and how to proceed with the calculations for the first and third questions.
There is a lack of clarity in the problem statement regarding the definitions and relationships between the variables, which has led to some confusion among participants. Additionally, the original poster has expressed uncertainty about how to approach the first and third questions after attempting the second.
NyghtLyght
Suppose for some unexplained reason you are skateboarding and wanted to use a spring to launch you off a ramp. Assuming you have a mass of 70 kg, if the spring has a spring constant k = 625N/m and is compresed 5m.
1.If the ramp has a 60° and is 10m long, will you make it off the ramp?
2. How high will you go?
3. How fast will it be going when it enters the ramp (ignore friction)?
1/2mv(intial)squared + mgh(initial) + 1/2k(initial)xsquared = 1/2mv(final)squared + mgh(final) +1/2k(final)xsquared
To get the first answer, the second question has to be answered. I got 1/2k(intial)xsqured = mgh(final). 1/2(625)(5)squared = 70(9.8)h(final). 7812.5 = 686h(final). 11.4m=h(final).
After this, I have no clue how to get the first and third question.
Thanks ahead of time.
To answer #1, you need to determine whether the result in #2 is higher than the end of the ramp.
In #3, I do not understand what "it" is.
The it in #3 is the skateboard... I think.
And the answer to #2 is 11.4m=h(finial). But I don't understand how to get the answer to number one.
I think I have the answers. Thanks for the help.
  • · Replies 20 ·
  • · Replies 17 ·
