How to ground EMF shielding/clothing?
  • Context: Undergrad
  • Thread starter Thread starter mcriv880
    Emf Ground
The discussion centers on the grounding of EMF shielding clothing, particularly hats, and the materials suitable for effective shielding across a range of frequencies, including radio, infrared, and X-rays. Participants explore the technical aspects of grounding and the properties of various metals used in EMF shielding.
  • One participant questions how to ensure grounding for EMF shielding hats lined with materials like nickel or silver, expressing uncertainty about the meaning of grounding in this context.
  • Another participant notes that typical tin-foil hats are not grounded, referencing an external article.
  • A reply emphasizes that the original question pertains to EMF shielding rather than simple materials like sandwich foil.
  • Concerns are raised about the difficulty of shielding against higher frequency X-rays, with a suggestion that normal clothing can block UV, visible, and infrared light, but that microwave and radio waves are of primary interest.
  • Participants discuss the types of metals suitable for shielding, with mentions of solid or mesh beryllium copper as effective for the RF spectrum.
  • There is a reiteration that the shielding must block a wide range of frequencies, not just radio frequencies.
  • Common conductive materials for EMF shielding are listed, including nickel, silver, copper, cobalt, and stainless steel, with a note that the choice depends on the specific application.
  • A participant explains that "grounded" typically means a conductor connects the object to ground, using ESD wrist straps as an example.
  • There is skepticism about the practicality of wearing materials that could block X-rays, with a comparison to the weight of lead aprons used in medical settings.
Participants express differing views on the practicality and effectiveness of various materials for EMF shielding, as well as the implications of grounding. There is no consensus on the best approach or materials for achieving comprehensive shielding across the entire spectrum of interest.
Participants have not fully defined the specific applications for the EMF shielding, and there are unresolved questions about the effectiveness of different materials against various frequencies.
mcriv880
For example if a hat is lined with nickel,
silver, EMF paint, etc. , then how do you
ensure the hat is grounded? I am a little
unsure what grounding means relating to
these forms of usage as I have seen EMF protective clothing advertised as grounded.By EMF I mean sufficient for all freq with the exception of possibly Gamma Rays but not a material that produces Gamma Radiation as a result of the interaction either. What types of metals, and or materials would you use? For
example nickel, silver, gold, etc?
I guess an X Ray hat would be an example
of what I mean but other examples of hats/clothing exist capable of
blocking a wider array of frequencies. So I know they are made by the military, and privately.
You didn't read my question I'm referring to EMF shielding not sandwich foil.
Once you get into the X-Ray range it becomes extremely difficult to shield against. The higher frequency x-rays start to penetrate even thick shielding. Since UV, Visible, and much of the Infrared bands are easily blocked by normal clothing, I assume you want to block mostly Microwave and Radio waves. To my knowledge a thin metal sheet or weave would easily work, but I am no expert on EMF shielding.
Yeah but what type of metal? X Ray hats can be bought online however I'm talking about the entire spectrum, and the manufacturing of one, not the purchase.
Solid or mesh beryllium copper is about the best low cost shielding for most of the RF spectrum. Is this for “electrosmog”?
No it's not only radio frequencies. The metal, or combo of metals must block radio, infared, x-ray, etc.
Typical Conductive materials for EMF Shielding and Conductive Fabric are Nickel, Silver, Copper, Cobalt, Stainless Steel. The selection depends on the application. For example, This Nickel/Copper coated polyester mesh window screen material provides >50dB over 10 MHz-3 GHz. See the selection chart at:
http://www.lessemf.com/fabric_guide.html
Bobbywhy
When the term "grounded" is used normally that means there is a conductor connected from the object to ground. Electronics assembler workers wear ESD wrist straps that have a wire connected to "GROUND" to discharge (or not allow) any electrostatic charge buildup on their bodies which can destroy sensitive electronics.
What is the application?
X-Ray hat? Unlikely. The required material would be far too heavy to wear. Just think of the lead apron you wear at the dentist or doctors office. It ain't light.
Not going to happen. Not unless you want to wear 10 pounds of lead on your head to block the X-Rays.
9K
  • Sticky
507K
