How is work dependent on displacement rather than distance?
  • Context: High School
  • Thread starter Thread starter pkc111
    Displacement Work
The discussion clarifies the concept of work in physics, specifically the equation work = force x displacement. It emphasizes that while pushing a box with a force of 10N over a distance of 1m results in 10J of work, returning the box to the starting point does not negate this work. Instead, the total work done is calculated as the sum of work in both directions, resulting in 20J. The concept of path integrals is introduced to explain how work is computed over varying forces along a path.
  • Understanding of Newton's laws of motion
  • Basic knowledge of vector mathematics
  • Familiarity with the concept of force and displacement
  • Introduction to calculus for understanding path integrals
  • Study the principles of Newtonian mechanics
  • Learn about vector dot products in physics
  • Explore the concept of path integrals in calculus
  • Investigate the implications of variable forces in work calculations
Students of physics, educators explaining work and energy concepts, and anyone interested in the mathematical foundations of mechanics.
pkc111
Using the definition of work=force x displacement (which I understand is correct):If I push a box along the ground with force of 10N over a distance of 1m and then back again to the starting point, the above eqn would indicate I have done zero work (because displacement =0). But my muscles have put a lot of work into the box (like force x distance)?
I would appreciate it if anyone could explain this?
Thanks very much.
If you push a box out and then back then this is not a case of constant force. The force times displacement formula only works for a constant force. So break the problem up into two pieces where the force is constant on each piece.
The work you have done pushing the box out is +10N times +1m = 10J. The work you have done pushing the box back is -10N times -1m = 10J. Total work done = 20J.
More generally the work done pushing an object along a path is the "path integral" of the vector dot product of instantaneous force times incremental displacement along the path -- in effect you break the problem down into lots and lots of small pieces where force and direction are approximately constant and then take the limit as "lots and lots" goes to infinity.
Great Thanks! That makes sense now
  • · Replies 48 ·
  • · Replies 17 ·
14K
  • · Replies 138 ·
9K
  • · Replies 34 ·
