Will the Safe Tip Over During the Emergency Stop?
  • Thread starter Thread starter Drespar
    Torque
The discussion centers on the dynamics of a safe in a truck during an emergency stop, specifically analyzing whether the safe will tip over. The truck's velocity is approximately 29.1 m/s, with a negative acceleration of -6.86 m/s² due to braking. Key factors include the safe's mass of 1063 kg and a friction coefficient of 0.8 between the safe and the truck bed. The normal force shifts towards the pivot point at the ledge, affecting the tipping point, which requires calculating the torque to determine the minimum force needed for the safe to tip.
  • Understanding of Newton's laws of motion
  • Familiarity with torque and pivot points
  • Knowledge of friction coefficients and their implications
  • Ability to construct and interpret force and torque diagrams
  • Learn how to calculate torque in static equilibrium scenarios
  • Study the principles of inertia and its effects on objects in motion
  • Explore the relationship between friction and tipping points in physics
  • Investigate real-world applications of these principles, such as vehicle safety design
Physics students, engineers, and anyone interested in understanding the mechanics of tipping and stability in moving vehicles.
Drespar
A safe is in the back of a truck resting against a ledge that is .0381 m high. The truck is traveling at a velocity of approx. 29.1 m/s (about 65 mph). The driver then is forced to make an emergency stop, causing a negative acceleration of -6.86 m/s2. (solved for the acceleration with friction and velocity).
What will the safe do?
The safe's mass: 1063kg
Friction Coefficient (safe on truck bed): .8
Force(net)x = 0
Force(net)y = 0
Torque(net) = r χ F
As it stands, I have tried to construct an extended Force & Torque diagram. The pivot point of the system is located at the top of the ledge. The object is not accelerating in either the x or y direction so the net force in those directions is 0.
My main issue, is why is the normal force shifted (I have looked for explanations, they show the normal force has shifted towards the pivot, but they don't say why). Additionally, I do not know how to solve the equation for the minimum force required to tip the safe.
Welcome to PF;
... I cannot tell what you have tried from just this.
You sound confused - start again from the beginning and go through it slowly.
The truck slams on the breaks ... the truck slows sharply... but the law of inertia means...
Is that all the info given? Is there a missing diagram?
Which side of the safe is the ledge? In front or behind? (It's not clear why you are given the coefficient of friction and a ledge).
Is the width and height of the safe given?
Why do you say that? If the safe isn't decelerating then there is no force causing it to tip over.
Because if it's just about to tip up "all the weight" is at the edge near the pivot and none onder the back edge. See youtube for video of motor bike doing a nose stand. As the back wheel is just about to lift off ground all the weight is on the front wheel.
At the point where it's just about to tip over the torque will sum to zero. Any more torque in the forward direction and it will tip over.
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 97 ·
  • · Replies 37 ·
