The Place of Natural Numbers in Axiomatic Mathematics
The discussion centers on the logical permissibility of using natural numbers as subscripts prior to their formal definition through the Peano Axioms. It highlights the interdependence of concepts such as functions, operations, and sequences, questioning whether "list-helper" natural numbers can be utilized before the Peano framework is established. The consensus suggests that while natural numbers can serve as pre-mathematical notions, their use in defining functions complicates the matter. The text "Foundations of Analysis" by Edmund Landau is recommended for further understanding.
  • Understanding of Peano Axioms
  • Familiarity with functions in mathematics
  • Knowledge of discrete ordered sets
  • Basic concepts of sequences and operations
  • Study the Peano Axioms in detail
  • Explore the role of functions in mathematical definitions
  • Investigate discrete ordered sets and their applications
  • Read "Foundations of Analysis" by Edmund Landau
Mathematicians, educators, and students involved in foundational mathematics, particularly those interested in axiomatic systems and the logical structure of mathematical concepts.
middleCmusic
I'm trying to write down an axiomatic development of most of mathematics, and I'm wondering whether it's logically permissible to use natural numbers as subscripts before they have been defined in terms of the Peano Axioms.
For instance... the idea of function is used in the Peano axioms (successor function), so clearly function has to be introduced before the Peano axioms. But the ideas of operation and sequence are closely related to the idea of a function, yet they use natural numbers either to denote the number of sets in a Cartesian product or the order of items in a list. So should those concepts come in a section about functions before the Peano axioms or afterwards? Do those "list-helper" natural numbers need to come after the Peano Axioms? Or are they simply "dummy numbers" and can thus come beforehand?
I guess it comes down to whether we're okay with accepting the natural numbers for use as a pre-mathematical notion when they're not being used explicitly, sort of how the ideas of "implies" and "for every" are simply logical prerequisites. However, if you take this approach, you get into some murky waters, as the sequence idea can also be introduced in terms of a function which has the natural numbers as its domain. In that case, where numbers are the input of a function, it seems that we are using the actual natural numbers, not simply the list-helper natural numbers.
Thoughts?
You need the text: Foundations of Analysis by Edmund Landau. Trust me. Buy it.
As far as "subscripts" are concerned, you don't need to use numbers- any discrete ordered set will do. But you do not need "subscripts" or sequences to use Peano's axioms.
Peano's axioms: the "natural numbers" consist of a set N and a function s from N to N such that:
1) There exist a unique member of N, 1, such that s is a function from N onto N-{1}.
2) If a set X contains 1 and, for any x in X, s(x) is also in X, then X= N.
  • · Replies 73 ·
10K
  • · Replies 64 ·
