Question on the Law of Reflection
The discussion revolves around the law of reflection, specifically examining the angles formed when a beam of light reflects off a horizontal surface. Participants explore the relationships between these angles and their sum, as well as the implications of viewing the reflective surface as a diameter of a circle.
  • One participant states that the law of reflection indicates the angle of incidence equals the angle of reflection and provides a specific example with a 45-degree angle.
  • The same participant proposes a relationship involving a third angle formed by the incidence and reflection, suggesting that the total of these angles should equal 180 degrees.
  • Another participant agrees with the understanding of the law of reflection but points out that angles are typically measured with respect to the surface normal rather than parallel to the surface.
  • A subsequent participant asks for clarification on whether all angles formed by the reflecting light are supplementary, implying they should total 180 degrees.
  • Another reply suggests that the statement about angles being supplementary holds true under the assumption of a flat surface, even if the angles of incidence and reflection are not equal.
Participants generally agree on the basic understanding of the law of reflection, but there is some confusion regarding the measurement of angles and the implications of viewing the reflective surface as a diameter of a circle. The discussion remains somewhat unresolved regarding the specifics of angle measurement and the conditions under which angles are considered supplementary.
There is a lack of clarity regarding the definitions of angle measurement in this context, particularly whether angles should be measured with respect to the surface normal or the surface itself. Additionally, the implications of the reflective surface being viewed as a diameter of a circle are not fully explored.
manofslate
The law of reflection states that the angle of incidence equals the angle of reflection.
In the event of a beam of light reflecting upon a horizontal surface, the incidence angle is 45 degrees (as a variable, 45 degrees will be represented by A).
The angle formed by the reflection will also be 45 degrees (demonstrating the law of reflection).
There is a third angle which has also been formed. If the line is horizontal (by horizontal, I mean that a perceived vertical auxiliary line could be drawn and intersect with the first line to form two right angles), then the total value should 180 degrees.
The values of the angles of reflection and incidence are equal, therefore I’ll refer to them both with the variable A. So, 2A is the value of both angles.
180 -2(45) = 90.
In between the two lines formed by the incidence and reflection of the beam of light, there exists a right angle (this surely must be the case because an additional ninety degrees is necessary to complete 180 degrees.
So, the third angle formed (with respect to the two angles formed by the reflecting beam of light) is summed up by the equation:
2A + X = 180
The variable X will be the remaining angle
Basically, if a reflective surface is horizontal, can this surface be viewable as the diameter of a circle, with a total angle measure of pi radians (180 degrees)?
If this is the case, then the angle in-between the angles formed by incidence and reflection must ensure that the total amount of degrees will equal 180 degrees, am I correct?
Sorry, it’s been a while since I’ve studied the law of reflection, but I’m still curious.
Oh, and forgive me if there are any fallacies. I'm only a sophomore in high school, and I really hastily scrawled this out.
Science news on Phys.org
Firstly, welcome to the forums!
Your understanding of the law of reflection is correct, except that angles in this context are conventionally taken with respect to the surface normal (not parallel to the surface).
I am also confused by this statement;
Claude.
Hey Claude,
Thanks for reading this. I didn't clarify on the aforementioned statement; mixing up on units and such. To make it simple, all of the angles formed by the reflecting light on the given surface are supplementary, correct? They must all total 180 degrees?
Only because you've assumed a flat surface. This would be true even if the angles of incidence and reflection were not equal. (Unless I missed your point.)
