Lasers on earth visible from Mars
The discussion revolves around the feasibility of a laser beam being visible from Mars when shone from Earth, particularly considering the power requirements and the effects of distance and atmospheric conditions. Participants explore the implications of different laser types and their focusing capabilities, as well as the theoretical power needed for visibility at such distances.
  • One participant questions the power required for a laser to be seen from Mars, suggesting various types of lasers ranging from guide star lasers to high-powered naval lasers.
  • Another participant notes that the human eye cannot resolve Earth from Mars due to the overwhelming sunlight, indicating that the visibility of the laser would depend on its focus and power.
  • A calculation is presented estimating that a 1mW laser pointer has a visibility range of 4000 km, implying that to be visible from Mars, a laser would need around 100 kW of power, assuming consistent focusing.
  • There is a discussion about the wavelength of the laser light, with a shorter wavelength potentially improving visibility but also presenting challenges in photon production.
  • One participant reflects on the implications of the power needed for visibility, relating it to science fiction scenarios involving laser propulsion from distant stars.
  • A suggestion is made that a larger telescope, such as the E-ELT, could allow for a lower power laser to be visible from Mars due to better focusing capabilities.
  • Another participant mentions the immense power requirements for direct propulsion using light pressure, providing a rough estimate of power needed for small masses.
Participants express various viewpoints regarding the power requirements and visibility conditions, with no consensus reached on the exact parameters or feasibility of the laser visibility from Mars.
Discussions include assumptions about laser focusing, atmospheric effects, and the impact of different wavelengths on visibility, which remain unresolved and depend on specific conditions.
andrewbee
Hi,
I read something interesting about some amateur astronomers lasing the ISS with a blue-light laser, and the astronauts were able to spot it.
How powerful would a laser have to be to be seen by the human eye from Mars? It would be shone from the dark side of Earth of course. Are we talking one (or several) guide star lasers from the big observatories? Metal-cutting beams (c. 50w)? Naval anti-missile experimental lasers (c. 100 kw)?
Any input appreciated.
Thanks
The human eye cannot resolve the disk of Earth from Mars, so you always have much more sunlight than laser light.
Even if we neglect this and just take the minimal distance (~55 million km), it depends on the focus of the laser beam: If you use a telescope (in the "wrong" direction of light) to focus the beam, the power can be reduced significantly compared to a regular laser.
Edit: For a laser pointer of 1mW, I calculated 4000km as lower bound on the visibility range a while ago. 10000 times this distance would need 100 million times the power, or 100kW, assuming the focussing remains the same.
That's really helpful,thanks. Did you make any assumptions about whether it was red, green or blue light?
700nm -> red
A shorter wavelength could improve the visibility limit a bit, but it also gives a lower number of photons per power, and it is harder to create.
That's surprising.
One of my favorite novels is https://www.amazon.com/dp/0974776963/?tag=pfamazon01-20, in which they propel a spaceship to Earth by the power of a laser shined from Alpha Centauri. If it takes 100kW just to be able to see it on Mars, it must take petawatts to propel a ship to the nearest star.
https://www.amazon.com/dp/0671741926/?tag=pfamazon01-20 is another novel that did a similar thing.
Well, such a system would have a much better focus than a laser pointer. If you use something like the E-ELT (40m-mirror, currently under construction), a strong laser pointer could be sufficient to be visible from Mars. The laser spot would have a diameter of a few kilometers there.
Direct propulsion with light pressure requires insane amounts of power - about 1 gigawatt (or 1 big powerplant) per 6N (enough to hold a mass 600g on earth), even if the whole laser hits the spacecraft .
  • · Replies 19 ·
