Improper intergral, infinite bounds of integration
The discussion revolves around the evaluation of improper integrals with infinite bounds of integration, specifically focusing on the integral of the function x^3 and its properties. Participants explore the convergence or divergence of these integrals, the implications of antisymmetry and symmetry in functions, and the handling of indeterminate forms like infinity minus infinity.
  • One participant questions whether the integral of x^3 converges to zero or diverges to infinity minus infinity, indicating uncertainty about the evaluation process.
  • Another participant argues that because x^3 is an antisymmetric function, the areas under the curve from positive and negative sides should cancel each other, but notes that the integral is ill-defined due to infinite areas.
  • A participant presents a specific example involving the integral of x/(x^2+1) and discusses the evaluation leading to an indeterminate form of infinity minus infinity, expressing disagreement with classmates who suggest convergence to zero.
  • Multiple participants assert that certain improper integrals are ill-defined and do not converge, providing examples where different limits yield different results.
  • Concerns are raised about notation and the treatment of limits in the context of Cauchy's principal value, with questions about the implications of symmetry and asymmetry in the functions being discussed.
  • Another participant emphasizes that infinity minus infinity is an indeterminate form and that divergent integrals cannot be equated to zero.
  • Discussion includes the idea that the integral of x^3, being an even function, should not cancel out due to symmetry, contrasting with the earlier point about antisymmetry.
Participants express disagreement on the convergence of the integrals discussed, with some asserting that they are ill-defined and divergent, while others explore the conditions under which they might yield different results. No consensus is reached on the evaluation of specific integrals or the implications of symmetry and antisymmetry.
Participants highlight limitations in their understanding of notation and the handling of infinite bounds, as well as the dependence on definitions related to convergence and divergence. The discussion remains unresolved regarding the specific conditions under which certain integrals may be evaluated.
nick.martinez
∫ x^3 dx =∫ x^3 dx+∫x^3dx
I split up integral and got (x^4)/4 and infinity when evaluating using limits. does the integral converge to zero or diverge to infinity minus infinity?
would really appreciate help answering this question.
Thanks
Well, because it's an antisymmetric function, from the graph you can see that the area from x>0 has the same magnitude as the area from x<0 but with a minus sign. Thus the integrals should cancel each other, but because their area is infinite this integral is ill defined.
So when do the areas cancel? Because on my last quiz i had this question.
∫[(x)/((x^2)+1)]dx
the antiderivative is:
(Ln|x^2+1|)/2 and i (Ln|∞+1|)/2-(Ln|∞+1|)/2
which gives ∞-∞.
by the way i got this answer by using limits. Some people in class were trying to say the function converges to zero but I disagree. Please elaborate if i am correct in this case on my quiz. and also when can i say ∞-∞ is equal to zero.
These sorts of itnegrals are ill defined, and don't converge not even to infinity.
Take for example:
[tex]\lim_{T\rightarrow \infty} \int_{-T}^{2T+1} x/(x^2+1) dx = \lim 1/2 ln(\frac{((2T+1)/T)^2 +1/T^2}{1+1/T^2})=ln 2[/tex]
and you can change the value of the integral as you see fit, perhaps 3T+1 instead of 2T+1, etc.
You see you get different values for this integral.
Take for example:
not quite sure what is going on in the notation. why is the positve infinity not 2t+1 and the negative bound on -T. And is this cauchy's principal because if so the question on the quiz didn't exlicitly ask for cauchys principal.
Take for example:
Also, when you say the function is asymmetric and so the areas should cancel, but since the limits of integration are infinite the function diverges. But when ∫x^3 dx we are essentially finding the area under the curve of (x^4)/4 which is an even function so the areas should not cancel because the function is symmetrical on both sides.
Thanks
Infinity minus infinity is not equal to zero. You have a divergent integral.
When you have an expression of infinity-infinity you get what is called indeterminate value, as in it could be any value you wish.
In the integral of x^3, you can pick any parameter T which approaches infinity.
For example we may take the integral between -T and T and get in the limit that it equals zero, or we may take from -T and T+1 and get that it converges to infinity.
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 31 ·
