Designing a Grounding System Simulator for Electrical Engineering Education
The discussion centers around the design and implementation of a simulator for protective grounding systems in electrical engineering education. The focus is on three types of grounding circuits: TT, IT, and TNC(s), with an emphasis on identifying appropriate protective devices and simulating the circuits for educational purposes.
  • Homework-related
  • One participant seeks assistance in designing a simulator for protective grounding systems, specifically mentioning TT, IT, and TNC(s) circuits.
  • Another participant requests clarification on the acronyms TT, IT, and TNC to better assist with the project.
  • There is a suggestion that TT, IT, and TN might be the correct terms, with a note on the TN-C-S system being a form of TN protective earthing.
  • A participant mentions the need for specific protective devices for each grounding system, indicating that different systems require different protections.
  • One participant provides a link to a resource listing various grounding systems as per BS 7671 Wiring Regulations.
  • The original poster expresses familiarity with grounding systems but seeks details on adequate protective devices such as fuses and relays for each circuit.
  • There is a mention of the intention to implement a circuit that includes a power supply, load (resistors), and protective elements, with specific devices needed for each grounding type.
  • The original poster plans to simulate these circuits in Simulink (MATLAB) before physical implementation.
Participants have not reached a consensus on the definitions of the grounding systems or the specific protective devices needed. Multiple viewpoints and clarifications are present, indicating an ongoing exploration of the topic.
There are unresolved questions regarding the specific protective devices required for each grounding system, and the discussion includes varying interpretations of the grounding system acronyms.
hawk_zoro
hi all dear members…
this summer i have a final year project to graduate as an electrical engineer …
my topic is to design and implement a simulator of a protective grounding system that contains the 3 types of circuits … that it :
TT, IT, and TNC(s) … and adding the adequate protective circuit and so on ….
i found some data but still not enough … would be glad if you help me here ….
thnks in advance …
Hawk .
thnks in advance …
Hawk .
Welcome to the PF.
Could you please say more about your project? Please define your acronyms (TT, IT, and TNC) for those of us not familar with them, so we can try to help. What web links will help us learn about your project?
Welcome to the PF.
actually i am asking you to help me...
wish that you can ...
thanks
He is trying to help you.
What does TT, IT and TNC stand for? Then we might be able to go from there.
thnks in advance …
Hawk .
Are you sure it's not TT, IT and TN? A TN-C-S system is a form of TN protective earthing (TN-S, TN-C and TN-C-S).
Anyway yes we can help you but you need to ask a question first. Are you looking for advantages and disadvantages of each system? Applications? Operation? Types of protective devices used?
http://www.neweysonline.co.uk/Earthing/Static.raction
There are five types listed in BS 7671 Wiring Regulations:
1.TN–S
2.TN–C–S
3.TT
4.TN–C
5.IT
The three systems used in the UK are: TN–S, TN–C–S (PME) or TT. However, because TT systems are not directly earthed they are prohibited for low voltage public supply in the UK.
thnks dude ...
well first i know almost eveything about each grounding system ..
what i don't know is what is the adequate protective device ( fuses and relays) for each circuit .. couz i heard that each one need specific protection ..
other thing .. i want to implement a circuit of that ..
i mean a sourse, a load (resistors) and protectice device and test it practically to see what's the advantage of grounding in the system ..
hope i make it clear ...
they stand for the 3 main grounding systems ...
TT = tera-tera = earth_earth
IT = don't know but we use an impredance here between the neutral and the groung
TNC(S) = tera- neutral ... and there r 2 different crts
my purpose is to implement a simulator ( circuit) that describes how the 3 types of grounding are working ...
for educational purpose .. that is i will let this circuit in my isntitut as a good example of grounding
the steps are ...
i need power supply ..
a load ( resistors) ...
and i need protective elements ...
and each type of grounding as a specific adequate protective element ...
example :
the TT grounding type needs the differential relay ...
the IT needs impedance controller and so on ...
so i need those details ..
i want to simulate them in simulink (matlab) before implementing the circuit ...
hope it is clear ...
please help me soon ...
time is running ...
