How to calculate electric charge with a given electric potential?
The discussion revolves around calculating the electric charge of an iron plate with a specified electric potential, focusing on the concepts of self capacitance and charge distribution. Participants explore the necessary parameters and equations involved in the calculation, as well as the implications of the plate's charge being positive.
  • One participant asks how to calculate the charge of an iron plate given its electric potential and mass, suggesting they have sufficient information.
  • Another participant points out the need for the plate's shape and questions whether self capacitance is being considered, stating that charge is the product of electric potential and capacitance.
  • A participant clarifies that they are discussing self capacitance and provides the dimensions of the plate, indicating uncertainty about how to calculate capacitance.
  • One participant notes that calculating capacitance for a non-symmetrical object like the iron plate will be complicated, referencing the electrostatic equation and suggesting that an exact answer exists but may be complex.
  • A participant inquires about differences in charge distribution between positively and negatively charged objects, specifically mentioning the positive charge of the iron plate.
  • Another participant refers to a Wikipedia page on self capacitance, providing an approximate formula for a circular disc and noting that thickness is less significant if the radius is much larger than the thickness.
  • One participant comments that the only difference in potential between positively and negatively charged plates is the sign of the potential, and discusses the use of cylindrical coordinates for calculations involving a flat disk.
Participants express varying levels of understanding regarding the calculation of capacitance and the implications of charge distribution. There is no consensus on the exact method to calculate the charge or the capacitance of the iron plate, and multiple competing views remain on how to approach the problem.
Participants mention the complexity of the charge distribution due to the non-symmetrical shape of the plate and the dependence on specific parameters like shape and dimensions for capacitance calculations. There are unresolved mathematical steps related to the electrostatic equations and approximations discussed.
Bobcent
Hi!
An iron plate with a mass of 1 kg surrounded by vacuum has an electric potential of +20 kV. How do I calculate the charge, Q of the iron plate?
I have all the information I need, right?
You also need the shape of the plate (thickness, diameter). And I don't know if you are talking about self capacitance here or if the plate is near another plate.
http://en.wikipedia.org/wiki/Capacitance#Self-capacitance
The charge of the plate is the electric potential times it's capacitance.
Thanks for your reply!
The iron plate is not near another plate, so I'm talking about self capacitance.
But I don't have the capacitance.
Is the capacitance a value based on the shape and the electric properties of the material? How do I calculate it?
Say that the shape of the 1 kg iron plate is a square with an area of 0.225 m^2. That makes the thickness 0.0025 m since the density of iron is 7874 kg/m^3.
It is going to be pretty complicated expression because it is not a highly-symmetric object. (For example, a sphere would give a nice answer). But for your problem, there is still an exact answer. Assuming the charges in the object are fixed, we than have the electrostatic equation:
[tex]\nabla^2 \phi = - \frac{\rho}{\epsilon_0}[/tex]
This is the 'exact answer' I was talking about. From here, it gets a bit complicated, because the charge distribution rho does not follow a simple symmetry. Of course, you could take the limit of some point near the surface of the object, in which case, you can get a simple (approximate) answer.
Thanks for your reply Bruce, and happy Easter!
Is there a difference in charge distribution for a positively charged object compared to a negatively charged object? The iron plate would be positively charged if that makes any difference.
Did you look at the wikipedia page for self capacitance? For a circular disc it's approximatly 8εr. r is the radius of the disc and ε = 8.85× 10−12 F/m. The thickness doesn't matter as long as the radius is much bigger than the thickness. So a thin big plate will have a larger capacitance than a small thick one.
the only difference in the potential for a positively or negatively charged plate is that the sign of the potential would be opposite. (using the convention that the potential at infinity is zero). Also, DrZoidberg brings up a good point. (p.s. I'm a futurama fan too). I guess that for a circular disk, you can use a cylindrical coordinate system, and take the approximation that the disk is very flat, then I guess it is not too difficult to do the calculation. I have not done this calculation myself, but I would guess that is the general idea.
  • · Replies 21 ·
