Understanding laws of thermodynamics
  • Context: Undergrad
  • Thread starter Thread starter apurvmj
    Laws Thermodynamics
The discussion revolves around the laws of thermodynamics, specifically focusing on energy transformations within a closed system consisting of a mechanical clock and vacuum. Participants explore concepts of potential energy, mechanical work, heat energy, and the implications for the first law of thermodynamics.
  • One participant questions whether the energy of the system remains the same at the initial and final stages, suggesting that energy is lost due to mechanical work and friction.
  • Another participant argues that in a perfectly sealed box, all mechanical energy would convert to heat, implying that energy is conserved in this ideal scenario.
  • A different viewpoint emphasizes that 'disorder' in the system relates to increased temperature and thermal motion, while noting that 'disorder' is a subjective term compared to the precise definition of entropy.
  • Concerns are raised about energy loss in real systems due to thermal radiation and vibrations, which could carry energy away from the system.
  • Some participants debate the nature of potential energy, mechanical work, and whether potential energy can be considered 'destroyed' in the process, questioning the implications for the first law of thermodynamics.
  • Clarifications are made regarding the conversion of potential energy to kinetic energy and the role of friction in mechanical work, with some participants asserting that energy is not lost but transformed.
  • Questions are posed about the necessity of energy to overcome inertia and whether energy conversion requires additional energy or occurs spontaneously.
Participants express differing views on whether energy is conserved in the system, with some asserting that energy is lost due to mechanical work and others claiming that all energy is converted to heat. The discussion remains unresolved with multiple competing views present.
Participants acknowledge various assumptions, such as the ideal conditions of a perfectly sealed box and the effects of real-world factors like thermal radiation and vibrations. The definitions and implications of energy forms and conversions are also debated without consensus.
apurvmj
say we have closed system (box) consisting vacuum and one mechanichal clock, wound to have (potential) energy (within spring) for say ten revoluntion for second hand in the begining.
now when watch is allowed to have ten revolution of second hand and then it stops at the same location at it started,
In the system, we should be having some heat energy released due to friction of mechanism and one dead clock.
now is the energy of the system at the initial stage and final stage is same?
has some energy lost in doing mechanical work, as not all energy is converted into heat?
what is the disorder in system?
Science news on Phys.org
No the at the final stage you don't have the energy that you did at the start in this configuration as the mechanical work has been done and you cannot reverse it so energy has been lost in it.
Now the heat energy will be there as heat depending on how tight and perfect the box is in a theoretical scenario all the heat energy generated by frictions should remain as heat in the perfectly sealed box.
Under the assumption of absolutely no energy loss from the box, the system will have the same energy at the end as in the beginning. All of the mechanical energy from the spring will be converted to heat and, for a while, mechanical energy due to vibrations of the clock frame (and these will slowly be converted to heat).
The 'disorder' in the system comes from its higher temperature. The atoms in the clock will increase their random thermal motion. You should know, though, that 'disorder' is an inexactly defined, subjective term, and the laws of thermodynamics apply to entropy rather than disorder. It is just that the common notion of disorder maps relatively well onto the exact definition of entropy when you take a molecular level view of things, so people talk about disorder in introductory treatments. But keep in mind that it only works reasonably well when you look at the molecular level.
There are a few sources of loss in a real system like this, though. First, there is thermal radiation, which is a bigger source of heat loss than most people realize. Just like if you heat metal hot enough, it will glow red, things at room temperature are already hot enough to glow infrared (which the human eye cannot see). You could reduce this with mirrors on the inside of the box between the vacuum and the clock. Secondly, if this is on Earth where there is gravity, there will be something connecting the clock to the box and the box to the ground. This could carry vibrations away or conduct heat away.
@ crazymechanic
when potential energy is 'consumed' in mechanical work and apart from heat energy no other energy is conserved can we say part of potential is 'destroied', thus violating first law of thermodynamics.
@LeonhardEuler
if all the potential energy is converted to heat then what made the mechanical work?
thanks
apurvmj said:
@ crazymechanic
@LeonhardEuler
thanks
Be careful. Potential energy is not converted into work. Work is a force times a distance, and you can talk about the amount of work done over a certain time period, but not about the amount of work in the system at a certain point in time. Potential and kinetic energy are things where you can talk about the amount in the system at a certain time.
The potential energy gets converted first into the kinetic energy in the clock hand moving. Most of that is dissipated as heat when the clock hand stops. Some of it causes the clock to vibrate. The vibration is a combination of potential energy (in the form of the distortion of the clock frame) and kinetic energy (in the motion of the frame).
I would not have said what crazymechanic said in the first sentence about not having the same energy at the end and at the start due to mechanical work being done.
Yes.
No. All the energy is converted into heat.
You can't say the PE was converted to "mechanical work done" AND "friction". The mechanical work done was due to the friction. You have double counted it.
don't we need energy to overcome the inertia of components of watch? and is it all that PE converted to heat after mechanical work beeing done?
one more question (apart from previously discussed one), does energy is required to convert one form of energy to another or is it spontanious.
thanks.
  • · Replies 46 ·
  • · Replies 37 ·
