What is the relationship between entropy and the irreversibility of a process?
  • Context: Graduate
  • Thread starter Thread starter Abigale
    Irreversible Process
The discussion centers on the relationship between entropy and the irreversibility of thermodynamic processes, specifically within a cylinder filled with gas undergoing isothermal compression, adiabatic expansion, and isochoric heating. It is established that during the irreversible process of isochoric heating, the total entropy change (Δs) for the gas and heat reservoir is greater than zero, indicating irreversibility. In a completely reversible cycle, the total entropy change is zero, but this cannot be achieved when heat exchange with a reservoir is involved, as the heat reservoir's entropy change is negative when it loses heat to the gas.
  • Understanding of thermodynamic cycles, particularly the Carnot cycle.
  • Familiarity with concepts of entropy and its mathematical representation (ΔS).
  • Knowledge of heat transfer principles, including isothermal and adiabatic processes.
  • Basic grasp of the laws of thermodynamics, especially the second law.
  • Study the implications of the second law of thermodynamics on irreversible processes.
  • Explore the concept of entropy in greater detail, focusing on its calculation in various thermodynamic processes.
  • Investigate the differences between reversible and irreversible processes in thermodynamic cycles.
  • Learn about heat reservoirs and their role in thermodynamic systems, particularly in relation to entropy changes.
Students and professionals in thermodynamics, physicists, engineers, and anyone interested in understanding the principles of entropy and irreversibility in thermodynamic processes.
Abigale
Hi,
I regard a irreversible cycle process.
It is a cylinder filled with gas, which underlies the following processes:
12: isothermal compression (reversible)
23: adiabatic expansion (reversible)
31: isochor heating (irreversible) [This happens by connecting the cylinder with a heat reservoir]
I have callculated for the irreversible process 13, that [itex]Δs_{\text{gas}} > 0[/itex] and [itex]Δs_{\text{heat reservoir}} >0[/itex].
So the [itex]Δs_{\text{gas+reservoir}}[/itex] for the full cycle should be >0.
If i would have a completely reversible process, would the enropy change of the working gas be zero?
(After the whole cycle?)
THX
Abby
Science news on Phys.org
In a completely reversible cycle the total entropy change is zero, yes. But in this case you cannot consider some heat exchange with the heat reservoir (it is irreversible).
Also, I have a question. How come [itex]\Delta S_{heat~reservoir}>0[/itex]? If the reservoir heats the gas, then by $$dS=\frac{\delta Q}{T}$$ this should give a negative or zero value (since we're talking of a reservoir, the heat exchange may be so small compared to the reservoir's capacity that one may just consider it zero). The reservoir heats the gas, thus [itex]\delta Q\leq0[/itex].
/Th
If the reservoir is at a higher temperature [itex](T_{hot})[/itex] than the system being heated [itex](T_{cold})[/itex] then entropy [itex]\delta Q/T_{hot}[/itex] is lost by the reservoir $$\Delta S_{heat~reservoir}=-\delta Q/T_{hot}$$ and entropy [itex]\delta Q/T_{cold}[/itex] is gained by the system. $$\Delta S_{system}=\delta Q/T_{cold}$$ The total entropy is $$\Delta S_{total}=\delta Q/T_{cold}-\delta Q/T_{hot}$$ which you can see is positive. Since entropy is lost by the reservoir, the change in entropy of the reservoir is negative, not positive.
  • · Replies 60 ·
11K
  • · Replies 22 ·
