IR lights reflecting off of windshield
  • Context: Undergrad
  • Thread starter Thread starter dotancohen
    Ir Lights
The discussion revolves around the potential effects of infrared (IR) lights from an in-car camera on the driver and passengers, particularly regarding reflections off the windshield and possible health implications. Participants explore concerns about eye damage, night vision, and the effectiveness of the IR illumination.
  • One participant expresses concern that the IR light from the camera's LEDs may reflect off the windshield and cause discomfort or health issues, including potential eye damage and effects on night vision.
  • Another participant questions the purpose of the IR lamps, suggesting that the unintended consequences of their use are more critical than their intended function.
  • A participant shares their experience with a similar camera, noting that the IR LEDs can be turned off and that they were ineffective for enhancing night vision.
  • Some participants argue that the energy output from the LEDs is unlikely to cause harm and that the eye does not respond to IR light, alleviating concerns about night vision impairment.
  • One participant cites an article suggesting a safe limit for IR exposure but agrees that the levels produced by the LEDs are unlikely to pose a risk.
  • Another participant emphasizes that while IR lasers can be dangerous, the LEDs in question are not focused beams and therefore should not pose the same risks.
  • A suggestion is made that using duct tape to cover the LEDs could effectively block the IR radiation.
Participants generally express a lack of consensus on the potential health effects of the IR lights, with some arguing that the risks are minimal while others remain concerned about the reflections and their implications.
There are unresolved assumptions regarding the physiological responses to IR light and the effectiveness of the camera's IR illumination. The discussion does not clarify the specific intensity of the IR light emitted by the LEDs.
dotancohen
I am considering purchasing an in-car camera such as this:
http://www.ebay.com/itm/Vehicle-Car...tal_Video_Recorders_Cards&hash=item4171ce36d5
The device has six infrared lamps to illuminate at night. I am concerned that a good portion of the light of those lamps will be reflected off the windshield and back at the driver and passenger. In addition to showing the reflection in the video, might there be any health effects from having this excess IR light in the cabin at night? Might it cause eye damage (seems unlikely, as there is other IR around, but this is probably more intense). Might it cause the pupil to contract, thereby reducing night vision? Are there any other ill effects possible?
Thanks.
Science news on Phys.org
What do you want those lamps to do?
it does not matter what I want them to do. What matters is that they may have unintended consequences of being lit. I was hoping that someone familiar with light, specifically the reflection of IR and human physiological responses to IR, would address the concerns mentioned.
I might be able to disable the IR LEDs by crushing them with pliers, but before I consider that I would like to hear an informed opinion.
Thanks.
I have a similar cam in one of my cars (that monitors teen drivers). You can turn off the IR leds in the setup menu. They (IR leds) were useless to extend the units poor night-vision anyway as the IR brightness is very low.
The LED's don't put out nearly enough energy to harm you and I don't believe your eye responds to IR light, so you shouldn't have to worry about losing your night vision.
Google found article here suggesting a safe limit is 100W per square meter..
http://www.safetyequipment.org/userfiles/File/ProUp_Oct09.pdf
As I understand it the problem with IR is that it doesn't cause the pupil to react. That means more IR light reaches the back of the eye increasing the risk of damage. However I agree with others that the level produced by these LEDs is very unlikely to cause any problems.
If the lights are supposed to be illuminating the whole field of view of the camera, they shouldn't be producing focused beams. You are right that IR lasers are dangerous for the reasons quoted (and because that you can't see the beam at all) but these are LEDs, not lasers.
Thank you. Turning the LEDs off is certainly preferable to popping them with a plier!
A small piece of duct tape will block all the radiation, if you just apply it over the emitting LEDs.
  • · Replies 152 ·
12K
17K
9K
  • · Replies 44 ·
16K
