Potential Energy/Work done paradox?
  • Context: Graduate
  • Thread starter Thread starter easwar2641993
    Paradox Potential
The discussion centers on the paradox of potential energy and work done when two bodies exert equal attractive forces on each other in a conservative force field. It establishes that when body A exerts a force F on body B, and vice versa, the work done against these forces results in a change in potential energy represented as ΔU = -2Fds. This conclusion highlights the complexity of calculating work done in systems where mutual forces are present, particularly when both bodies are in motion.
  • Understanding of conservative force fields
  • Familiarity with potential energy concepts
  • Basic knowledge of work-energy principles
  • Fundamentals of Newton's third law of motion
  • Explore the implications of Newton's third law in conservative systems
  • Research the mathematical formulation of potential energy in multi-body systems
  • Study the concept of work done in non-inertial reference frames
  • Investigate the relationship between force, distance, and energy in gravitational fields
Physicists, engineering students, and anyone interested in the principles of mechanics and energy conservation in multi-body systems.
easwar2641993
We all know that whenever an object is subjected to move against a conservative force field by an external agent,work should be done to do that.Let that work be W(applied). This is stored as Potential energy of the system.
If F is conservative force acting on a body and if we move that body against that force,then potential energy change ΔU equals W(applied) or negative of work done by the force(W(force).
ΔU = W(applied)= -W(force).
If there are two bodies in space,A and B. A exerts an attractive conservative force F and similarly B exerts the same force F on A. Just like "unlike" charges in electrodynamics. If A is fixed and B is allowed to move away from A ,so that attractive forces of each other pull each other. To move B away from A by a small distance ds, work should be done.And this is stored as potential energy of the system and is equal to the negative of the work done by the attractive force F of A.
ΔU=-Fds
This is common.Very common to everyone.Now my question.
If A exerts a force F on B and B exerts the same force F on A ,then we really have to do work against the attractive force of A on B and at the same time,attractive force of B on A,right?
I think the above works if above bodies are unlike charged particles.Because,there should be a central force of magnitude 2F pulling each other.
Hence , ΔU=-2Fds
In a frame where they both move you do work on both, but the distance is less.
  • · Replies 54 ·
  • · Replies 48 ·
12K
  • · Replies 16 ·
