Integral Form of the Momentum Equation - Reducer Question
The discussion revolves around a homework problem involving the evaluation of the total force required to support a reducer in a fluid dynamics context. Participants explore the properties of the reducer, the fluid being pumped, and the relevant equations for calculating the force based on momentum principles.
  • Homework-related
  • One participant presents a problem involving a reducer with specified dimensions and fluid properties, seeking assistance in calculating the total force required.
  • Another participant provides a numerical answer for the force but requests the working steps to arrive at that answer.
  • Several participants clarify the function of a reducer, explaining that it connects pipelines of different diameters.
  • There is a discussion about the nature of the reducer's volume, with participants suggesting it may refer to a tapered section of pipe or a cast fitting with a curved transition.
  • One participant expresses uncertainty about their methods after arriving at an answer, seeking validation from others.
  • A later reply references a previous discussion to suggest that the change in momentum of the oil should be equated to the force exerted on the reducer.
Participants generally agree on the function of the reducer and the relevance of momentum principles in calculating the force. However, there is no consensus on the specific methods used to arrive at the solution, and some participants express uncertainty about their approaches.
Participants mention various assumptions regarding the reducer's design and the fluid dynamics involved, but these assumptions remain unresolved and may affect the calculations.
MrWinesy
The internal volume of the reducer is 0.2m^3 and its mass is 25 kg. The fluid being pumped is oil (specific gravity of 0.72).
Evaluate the total force that must be provided to support the reducer.
d1 = 0.4m
d2 = 0.2m
u1 = 3m/s
p1 = 58.7 kPa
p2 = 49kPa (gauge)
Qin=Qout
mdot=ρ*A*u
A=(∏*d^2)/4
Tried. Failed. Help.
the answer is apparently F = −3.4xˆ +1.66yˆ kN but I am in need of the working please.
A reducer couples a larger diameter pipeline to a smaller diameter pipeline, hence the two diameters specified in the OP.
Thanks SK!
But - what is meant by its volume? Is it a tapered section of pipe going from the larger to the smaller diameter?
It can be. More often it is a cast fitting, either flanged or suited to welding, with a curved transition between the larger and smaller diameters, so that the overall length of the fitting is kept small. The volume, I believe, is just what it implies, the volume of the internal space of the reducer.
yea this is right. it can be basically thought of as a converging pipe and the question is based on the internal volume as this helpful fella said. and the mass is the mass of the actual reducer.
i have obtained the answer but not confident on my methods. anyone else had any luck?
Thanks to my friend Chestermiller from a similar previous problem, the approach here is to consider the change in momentum per unit time of the oil and equate that to the (longitudinal) force exerted on the reducer.
  • · Replies 25 ·
