How useful is topology in physics?
  • Thread starter Thread starter V0ODO0CH1LD
    Physics Topology
The discussion centers on the usefulness of topology and other advanced mathematics in understanding physics, particularly in the context of theoretical frameworks and unification of physical principles. Participants explore the relevance of topology in various branches of physics, including general relativity and quantum mechanics, while also considering the necessity of abstract mathematics for comprehending physical theories.
  • Some participants propose that topology is important for a rigorous understanding of the mathematics underlying various physical theories, particularly in general relativity and quantum mechanics.
  • Others argue that while topology and abstract mathematics can enhance understanding, they are not strictly necessary for grasping the physical concepts, suggesting that one can learn physics without delving deeply into these areas.
  • A participant mentions that formalism may not always illuminate physics directly but can offer insights into generalizing theories and hints toward unification.
  • There is a suggestion that for advanced topics like axiomatic quantum field theory, a comprehensive understanding of mathematics is required, including both algebraic and geometric formalisms.
  • One participant expresses skepticism about the necessity of topology in most physics, stating that it is not typically part of the standard curriculum.
  • Another participant acknowledges that while conventional physics often requires only basic differential geometry, certain phenomena, such as the Bohm-Aharonov effect, do involve topological concepts.
Participants express differing views on the necessity of topology in physics. While some assert its importance for a deeper understanding, others contend that it is not essential for most areas of physics. The discussion remains unresolved regarding the extent to which topology and other advanced mathematics are needed for a comprehensive grasp of physical theories.
Participants highlight that the relevance of topology may depend on the specific area of physics being studied, with some suggesting that basic differential geometry suffices for conventional physics, while advanced topics may require more extensive mathematical knowledge.
V0ODO0CH1LD
Whenever I try to understand deeper aspects of the higher maths involved in physics I keep hearing about topology related stuff. How useful is it to learn topology in order to get a deeper understanding on the maths behind physics? Also, what other maths should I look into? Functional analysis? Calculus of variations?
If you want a rigorous understanding of the math behind many different physical branches then yes topology is quite important. In general relativity for example, differential geometry is the natural setting which is built heavily on topology. The natural setting for QM is functional analysis which is also heavy on topology, as well as real analysis.
It is of course not necessary to know the abstract mathematics in order to understand the actual physics so if your main goal is to know the physics then understanding the abstract mathematics would be secondary (for example you can very easily understand the physical content of Noether's theorem and the link between Hamiltonian and Lgrangian mechanics in the usual language presented in second year mechanics texts - you don't need to understand the underlying machinery of legendre transforms as maps between the cotangent and tangent bundles of the configuration space and know about the relationship between lie group actions on the cotangent bundle and the resulting exp induced vector fields relating to conserved quantities etc.)
As for the question "what good does formalism do?", while it may not cast significant light on the physics in and of itself (but I think this is subjective), or be useful in computations, it may provide clues about how to generalize a theory, or hints toward unification.
However, often formalism goes a long way. For example, some basic things about qm, like the impossibility of duplicating states, follows quite easily from the Hilbert space formalism.
For the "basic" stuff, e.g. general relativity and nonrelativistic qm, you would be well off with elementary differential geometry and functional analysis. Classical mechanics basically studies flows on symplectic manifolds, etc.
I think this article: http://ncatlab.org/nlab/show/physics and the ones it links to, documents most of the mathematics used in modern physics.
For the really heavy duty stuff at the end of the spectrum, e.g. axiomatic qft, you need just about everything. There is a kind of duality going on, where you have equivalent algebraic and geometric formalisms. Check out the "Related consepts" at ncatlab.org/nlab/show/AQFT
so is it the case that if I want to understand the generalizations and unifications of "all" principles of physics I should probably get used to the fact that I will have to look into "all" of mathematics?
I disagree. The vast majority of physics does not require topology. Studying it won't hurt you, of course, but it is not something on the standard curriculum.
Who knows? We haven't seen all unifications and generalizations yet. But for the ones people are trying to accomplish, namely quantum gravity and TOE's, you already need a fair bit. I found this text a while ago. Maybe it can give you an idea of the scope.
http://people.math.jussieu.fr/~fpaugam/documents/enseignement/master-mathematical-physics.pdf
However, as Vanadium 50 says, for "conventional" physics you rarely need more than basic diff. geometry. Sometimes you need more, like very basic algebraic topology, as when discussing the Bohm-Aharanov effect or other phenomena where topological quantum numbers arise.
There is a very nice explanation of why there are only bosons and fermions in 3 dimensions, and why anyons with fractional spin can exist in 1 and 2 dimensional systems which uses a fair bit of topology:
www.ifi.unicamp.br/~cabrera/teaching/referencia.pdf
11K
  • · Replies 43 ·
11K
  • · Replies 36 ·
