Absoprtion specrum, identifying the 1 electon atom
  • Thread starter Thread starter CV101
    Atom
The discussion focuses on identifying an unknown one-electron ion, specifically He+, using the absorption spectrum data provided. The energy transitions listed are 1646254.1 cm-1, 1560886.3 cm-1, and 1316965.2 cm-1. The key equation used is Delta E = Rh (1/nf2 - 1/ni2), where Rh is the Rydberg constant. The discussion highlights the challenge of deriving integer values for quantum numbers and suggests that the unknown ion may be beryllium (Be) based on the ionization energies.
  • Understanding of one-electron ions and their energy levels
  • Familiarity with the Rydberg formula for spectral transitions
  • Basic knowledge of quantum mechanics and quantum numbers
  • Experience with interpreting absorption spectra
  • Research the Rydberg constant and its application in spectral analysis
  • Study the quantum mechanical model of one-electron ions
  • Explore methods for calculating ionization energies for different elements
  • Learn about the significance of energy level transitions in spectroscopy
Students studying quantum mechanics, physicists analyzing atomic spectra, and chemists identifying elements through spectral data.
CV101
The energies of some transitions observed in the absorption spectrum of an unknown one electron ion ( eg He+) are listed. Given that these transitions originate from the lowest energy level suggest an identification of the unknown ion
UNKNOWN ION (CM^-1)
1646254.1
1560886.3
1316965.2
ok, i am using Delta E = Rh (1/nf^2 - 1/ni^2) where f stands for final and i for initial
the problem is that I am not getting numbers close to integer values. I am not sure if the q even requires a numerical answer, as 3 ionisation energies must mean that the element is Be. I really don't know where to start. pls help
These are "some transitions", so it is not a complete list of three ionization energies.
Obvious line of attack is to try to find Z from the data given.
How?
how would you find z? sorry, I have no clue
  • · Replies 25 ·
11K
  • · Replies 38 ·
21K
14K
17K
