My Lamp Problem: Touch-Activated Unexplained On/Off
  • Context: High School
  • Thread starter Thread starter T@P
    Lamp
The discussion revolves around a touch-activated lamp that exhibits unexpected on/off behavior. Participants explore potential explanations for the lamp turning on by itself, considering various factors that might influence its operation.
  • One participant describes the lamp's behavior, noting it turns on unexpectedly after being turned off, suggesting a possible malfunction related to its capacitor.
  • Another participant inquires about environmental factors that could affect the lamp, such as moisture, pets, or other devices in the room.
  • A later reply hints at the age of the lightbulb as a potential factor, suggesting that movement rather than direct contact may influence the lamp's operation.
  • One participant proposes that a loose connection in the lightbulb could cause intermittent contact, leading to the lamp turning on and off based on vibrations.
Participants do not reach a consensus on the cause of the lamp's behavior, with multiple competing explanations and hypotheses presented throughout the discussion.
Participants mention various factors that could influence the lamp's operation, but there is no resolution on the specific cause of the issue. The discussion includes assumptions about the lamp's design and the environment in which it operates.
T@P
ok first of all this is not a puzzler and i don't know the answer, so don't make stuff up since i won't be able to tell :).
with that said, i have a a lamp that turns on when you touch it. (you could probably figure that out since i posted stuff about it before.) it is near my bed, and it is not unlikely that i touch it accidentaly in the night, turning it on. it has three levels of brightness (controlled solely by touch).
this night, i remember waking up constantly to turn it off because it was turning on. so this morning, i turned it off when i woke up. about 10 minutes later, it just turned on again. i was in the room those 10 minutes and didnt touch it. so, i got confused and turned it off again. about 7 minutes later ( i timed it sort of) it turns on again. so i turn it off for the last time and it doesn't turn on at all (on its own).
my question is (duh) how does it do that? from my previous post i know that there's a capacitor in it, and when you touch it, you briefly charge the teeny capacitor and it turns on. so either something messed up inside it, or the capacitor just charged itself. anyone have an idea?
Is there any thing that is touching the lamp at all? Including moist air? Do you have a cat? Is there an ionizing air filter in the room? Have you questioned all your gnomes and elves? I'm just tossing ideas here.
lol actually i figured it out. no cats ;) its quite funny and probably figure-outable from what said before.
in case its not, here's a hint: the lightbulb is old. and i wasnt sitting motionless in a chair while i waited (after turning it off). but i wasnt exactly making earthquakes either.
oh and this would work in a prison cell that contained only my lamp and me (i.e. no ionozing filters etc.)
aww no one gets it. well, ill give my explanation then: the lightbulb was messed up, and the wire was barely touching. that way, when i touched it, i didnt turn it off, i simply moved it which un-aligned the filament in the lightbulb which made it go off. then when i moved something else, the vibration restored contact and it went on again. after two times like this it stayed off for good. see? what tipped me off was when it started blinking rapidly... lol
That susually a sign :)
