Is a Chinook-Style Design the Key to a Successful Rubber Motored Helicopter?
  • Context: Engineering
  • Thread starter Thread starter ac16690
    Helicopter Rubber
The discussion revolves around the design and optimization of rubber motored helicopters for a Science Olympiad project, specifically focusing on Chinook-style helicopters. Participants explore various design considerations, efficiency equations, and experimental approaches to enhance flight performance.
  • Homework-related
  • One participant questions whether the rule granting Chinook helicopters three times their flight time is intended to encourage that design or if it indicates a greater complexity in construction.
  • Another suggests that conducting experiments may be more effective than searching for equations to optimize helicopter design.
  • There is a discussion about synchronizing dual rotors to allow them to be positioned closer together without colliding, raising questions about the efficiency of overlapping rotors.
  • Concerns are raised regarding stability if one rotor produces more lift than the other, potentially leading to a rollover.
  • A participant proposes tilting the rotor axes towards each other as a method to manage lift imbalances and reduce torque issues.
Participants express various viewpoints on the effectiveness of Chinook designs and the importance of rotor synchronization, but no consensus is reached on the best approach or design principles. The discussion remains unresolved with multiple competing ideas presented.
Participants note the lack of specific equations for rotor efficiency and the potential limitations of existing models. There is also an acknowledgment of the need for experimental validation of proposed designs and concepts.
Students and educators involved in science projects related to aerodynamics, helicopter design, and experimental physics may find this discussion relevant.
ac16690
For a Science Olympiad project I need to make a rubber motored helicopter, and with this I need to find the best design for one. One special rule in this is that Chinook styled helicopters get 3x their original flight time, I was wondering if that would be just to encourage students to do that type of helicopter, or if they are just harder to make. Also i have been looking for formulas about the efficiency of helicopter rotors with no success. Most models I have seen were Chinook helicopters and they were made from Balsa wood. Any help with some equations to help me out with lift or drag would be helpful.
N/A
I have tried researching equations, and have also asked my teacher and she left me with more questions than answers because she wants me to figure it out. Luckily this is due May 28th so I have awhile and I was spending hours on typical helicopter designs with no avail.
N/A
Perhaps it's time to try some experiments, eh? It may be easier to optimize your work through experiment rather than trying to find equations for the situation.
Since balsa wood helicopter kits are common and cheap, can you think of some experiments that you can use to try to optimize a design for this assignment? And is there a way you can experiment with the dual-rotor configuration?
BTW, one of the optimizations used in dual rotor helicopters is synchronizing the two rotors so they can be closer together without banging into each other. How can you do that in a balsa-wood experimental model?
I'm wondering if the induced wash from overlapping rotors reduces efficiency. Maybe this is done to reduce size? One of the rotors could be just mounted higher than the other to prevent the rotors from colliding. The real Chinook rotors are synchornized via a shaft. The rear rotor is slightly higher than the front, but not by enough to avoid the rotors hitting each other if they weren't synchronized.
I would be a bit concerned about stability. If one rotor produces more lift than the other it is likely to turn over.
I'm wondering if tilting the axis of the rotors slightly towards each other would help. Initially an imbalance would produce an imbalancing torque, but the lower lift producing rotor would become more horizontal and the higher lit producing rotor would become less horizontal, providing forwards or backwards thrust. The forwards or backwards thrust would result in forwards or backwards movement of the helicopter, reducing the imbalance in torque.
Certainly worth trying. Similar to dihedral.
  • · Replies 20 ·
  • · Replies 23 ·
9K
19K
17K
