Can a Ball in ℝn Be Proven as a Jordan Region with Zero Volume?
  • Context: Graduate
  • Thread starter Thread starter sammycaps
    Ball
Any ball in ℝn is proven to be a Jordan region by demonstrating that its boundary has Jordan content zero. The proof involves covering the boundary with horizontal lines and squares of side length ε, establishing that the volume of the boundary can be bounded by an arbitrary ε, thus confirming its content is zero. The discussion also highlights the relationship between Jordan and Lebesgue measures, noting that a compact set with Lebesgue null set properties is also a Jordan null set. This distinction is crucial for understanding the differences between Riemann and Lebesgue integrability.
  • Understanding of Jordan measure and Jordan regions
  • Familiarity with Lebesgue measure and Lebesgue null sets
  • Knowledge of Riemann integrability concepts
  • Basic principles of covering sets in ℝn
  • Study the properties of Jordan measurable sets and their relationship to Lebesgue measurable sets
  • Explore the concept of compactness in metric spaces and its implications for measure theory
  • Learn about the differences between Riemann and Lebesgue integrability in detail
  • Investigate examples of sets that are Jordan measurable versus those that are not
Mathematicians, students of real analysis, and anyone interested in measure theory and integration concepts.
sammycaps
I was trying to show that any ball in ℝn is a Jordan region, and this amounts to showing that its boundary has volume zero (Jordan content 0).
My TA proposed that you break the circle up into pieces of lines, and then adapt the following proof.
Pf: A Horizontal line of length 1 has content 0
A horizontal line of length 1 in ℝ2 has volume 0 because if you cover it by n intervals of length ε, you see that nε=1 (or something like 1+ε*γ for some γ<1, if ε doesn't divide 1).
So, then define a grid of squares with sides ε. Then the volume of the grid, which bounds the volume of the circle, is ε2*n but since nε=1 (or about 1), you get ε2*(1/ε)=ε, and so we can bound the volume by an arbitrary ε, so the boundary of the ball has content 0.
The TA actually did this with balls instead of squares (i.e. balls of radius ε), but since we're trying to prove that a ball is a Jordan region, I wasn't sure about this.Anyway, I was not sure how to adapt this proof to the curved line, since there is no guarantee that the curved line will only pass through n of the squares of volume ε2. I've seen at least 1 other way to do this with the compactness of the circle, but I was hoping that I could understand the TA's way.
Thanks.
I'm sure you can adapt the proof. In such a case, where we have a compact set (the boundary) which is a Lebesgue null set, it is also a Jordan null set and vice versa. The two measures on ball, open ball, and boundary are the same. The Jordan measurable sets don't form a ##\sigma-##algebra, so in order to find a set which is of a different measure or not Jordan measurable at all, we have to find a countable union of Jordan measurable sets which is not Jordan measurable.
In the end it is the same difference than between Riemann integrability (Jordan measure) and Lebesgue integrability (Lebesgue measure) - and the ball isn't an example where the two are different.
  • · Replies 16 ·
27K
