Common Technical Name for Spring Release Pin
The common technical name for the spring-loaded pin discussed is "quick-release pin." This type of pin is designed for rapid engagement and disengagement, making it ideal for applications requiring frequent assembly and disassembly. The discussion references two specific suppliers, Reid Supply and McMaster-Carr, which offer various quick-release pins and accessories. Users are encouraged to explore these sources for purchasing options and further information on specifications.
  • Understanding of mechanical fasteners and their applications
  • Familiarity with quick-release mechanisms
  • Knowledge of sourcing industrial hardware
  • Basic comprehension of scaffold hardware types
  • Research "quick-release pin specifications" for detailed technical information
  • Explore "Reid Supply quick-release pins" for product options and pricing
  • Investigate "McMaster-Carr quick-release pin catalog" for a broader selection
  • Learn about "scaffold hardware types" to understand the differences between spring-loaded and gravity-activated clamps
Mechanical engineers, industrial designers, and anyone involved in the assembly and disassembly of equipment requiring quick-release mechanisms will benefit from this discussion.
Josh11
Does anyone know what the common technical name for the attached image of a spring loaded pin? I am pretty sure it is on the market, but not sure what it is called. Maybe you have used them before.
*Note: This is similar to some scaffold clamps, but it is spring loaded, while some scaffold clamps are gravity activated.
  • · Replies 22 ·
