Register to reply
Advantage of using a bigger pulley in belt drive?
by hihiip201
Tags: advantage, belt, bigger, drive, pulley
Share this thread:
hihiip201
#1
Apr17-13, 01:59 AM
P: 163
Hi :
lets examine the following scenario
1.
M --------- o where M is a mass, o is a pulley with it's outter radius r attached to a mass by the belt drive -------. frictionless.
2.
M ---------O same setup but the radius is now bigger, R.
I was reading somewhere saying, a smaller pulley can move things quicker, so i decided to derive this to see for myself.
the following is the result:
for case 1:
alpha = T/(J+Mr^2)
case 2:
alpha = T/(J+MR^2)
in other word, for the same torque generated from DC motor, alpha is higher for case 1.
also, in the case where the pulley rotates at a constant velocity, constant torque output, case 1 amplify the force on the mass M where as the force on the Mass M in case 2 would be lower.
so my question is, why would anyone choose case 2 at all? what advantage does it have on any applications?
thanks
Phys.Org News Partner Physics news on Phys.org
New complex oxides could advance memory devices
Nature's designs inspire research into new light-based technologies
UCI team is first to capture motion of single molecule in real time
CWatters
#2
Apr17-13, 02:53 AM
P: 3,264
In this contect "constant velocity" means "constant angular velocity". So with the smaller pulley the force available to accelerate the object will be greater but the linear velocity of the belt will be lower.
Changing r is like changing gear on your car.
hihiip201
#3
Apr17-13, 03:20 AM
P: 163
Quote Quote by CWatters View Post
but wouldn't the mass still be able to moved quicker though since for a constant T the force on the mass would be higher?
I know this is related to how if you rotate a disk from its side you apply less force but cover more distance, vice versa, but i don't know how to apply that principle in this case.
CWatters
#4
Apr17-13, 03:41 AM
P: 3,264
When you say "moved" you need to be clear if you mean "moved at a constant velocity" or "accelerated"?
If the system is frictionless and the mass is moving horizontally it takes no power (no torque) to move the mass at a constant velocity. The maximum velocity will depend on the motors angular velocity and the gearing. The radius r is part of the gearing.
If you are accelerating the mass or raising it up an incline then that's a different matter.
Register to reply
Related Discussions
Belt drive pulley Engineering, Comp Sci, & Technology Homework 1
Golf : Advantage of a longer drive ? General Physics 13
[Theory of Machines] Why is Belt in a Belt drive a Link... Engineering Systems & Design 5
Belt drive problem Introductory Physics Homework 0
Belt Drive Introductory Physics Homework 1
