New Engine technology: no camshafts
  • Thread starter Thread starter Naty1
    Engine Technology
The discussion revolves around a new engine technology that eliminates camshafts by using independent actuators for each valve. Participants explore the claims of improved fuel efficiency and power, as well as the implications of this technology for engine design and performance.
  • Some participants mention that the technology claims a 20% improvement in fuel efficiency and increased power, though details on the mechanism are limited.
  • One participant describes the actuators as cylinder-shaped and self-contained, allowing for arbitrary valve timing and rapid opening and closing cycles.
  • A modified cylinder head on a Saab 95 has reportedly undergone endurance testing for two years, suggesting practical application.
  • Another participant recalls a historical context, noting that similar hydraulic valve actuation systems were designed decades ago, questioning the novelty of the current technology.
  • Some participants express skepticism about the technology being groundbreaking, citing previous developments in variable valve timing and actuation systems.
  • There is mention of pneumatic actuation as a potentially quieter alternative to hydraulic systems, though some express doubt about its suitability for high-speed operations.
  • One participant appreciates the design of the actuators compared to traditional camshaft systems, suggesting that independent actuation is a logical evolution in engine design.
Participants express a mix of curiosity and skepticism regarding the novelty and effectiveness of the technology. While some acknowledge potential benefits, others highlight historical precedents and question whether the advancements are truly innovative.
Participants reference various historical technologies and designs, indicating that the discussion may be influenced by prior knowledge and experiences with similar systems. The exact mechanisms and performance metrics of the new technology remain unclear.
Readers interested in automotive engineering, engine design innovations, and the evolution of valve actuation technologies may find this discussion relevant.
Naty1
I'm not able to watch YouTube videos from work. How is this done?
Independent actuators on each valve. The actuators are cylinder shaped surrounding the valve stem. Unsurprisingly, they don't say EXACTLY how it works but the actuators appeared to be self contained apart from electrical connections.
As well as an arbitrary valve timing, they are give close to a a "square wave" opening and closing cycle - about 3ms to move the valve fully, independent of engine RPM.
They showed a modified cylinder head on a Saab 95, which has run 2 years / 60,000 km endurance testing.
Since the valve cycle is completely arbitrary, one of their future ideas is to use the engine as an air pump for regenerative braking, and use the stored compressed air instead of a turbo boost.
The company is a small Swedish sports car manufacturer.
They claim a conventional 4-cyl engine could be replaced by a 3-cyl because of the increased valve efficiency, and after deleting the cam drive system etc, the engine would only be half the original length - and also shorter without the height of the cams over the valves.
I didn't bother watching more than 1/3rd of that for one reason—it's nothing new. If you remember, soon after I joined here about 15 or so years ago, I mentioned that I had designed a 2,000hp engine for my Roadrunner back in the late 70's. It was based upon a McGee (Kangaroo) block/head assembly, but the main reason for the outrageous power was a computer-controlled hydraulic valve actuation system that had been designed in Sweden. Overall power is determined by the lift of the valves, but the power band relies upon duration. My modification to the Swedish design was that rather than plugging a programmed chip into the controller, I fed the signals from a tachometer. That way, no matter what rpm the engine was running at, the duration varied to make sure that the engine was always in the middle of its power band and at maximum allowable lift.
Someone in the US, at the same time, came up with valve actuators called "helinoids" which also allowed for individually variable valve timing, but not lift. They were conical solenoids that, at 12VDC, could pull something like 200 lbs. in about a millisecond over a distance of 1/4" or so. Leverage was employed to get the desired lift.
This is still an interesting topic, but let's not think that it's ground-breaking technology.
I had wondered how old the technology was...video published 2/2013 so I hoped it was something new..
What does seem different about this is that the fellow mentioned pneumatic actuation. To me, that seems a bit odd for such a high-speed operation, but I suppose that it would provide less noise and vibration than hydraulics would.
I agree the basic idea of independent actuators seems a fairly obvious way to fix the limitations of a camshaft.
But those cylinder actuators look neat compared with the "obvious" design of keeping everything the same, except for poking the end of the valve stem with something that isn't driven by a cam.
  • · Replies 39 ·
  • · Replies 18 ·
  • · Replies 133 ·
29K
  • · Replies 72 ·
14K
