Cheap and low power diesel engines
The discussion centers on finding the cheapest and lowest power diesel engine, specifically a 3 KW engine, suitable for a college project. Participants explore options, pricing, and availability of small diesel engines and generators.
  • Exploratory, Technical explanation, Debate/contested, Homework-related
  • One participant inquires about the availability of a cheap and low power diesel engine, specifically seeking a 3 KW engine with minimal weight.
  • Another participant notes that small diesel engines require precise fuel injectors, which can be expensive, suggesting that truly cheap small diesel engines may not be available.
  • A suggestion is made to consider portable multi-fuel generators used by the military, with a caution that smaller units are generally not available at low prices.
  • A participant mentions a Subaru brand portable generator with a 3300 watt output priced at approximately $3300, indicating that the cost includes the generator itself.
  • Another participant points out the availability of a 6hp diesel engine on Amazon for about $500.
  • A further contribution lists a diesel engine available on eBay for $300, providing a specific link to the listing.
Participants express differing views on the availability and pricing of small diesel engines, with no consensus on a specific model or price point that meets the initial inquiry.
Participants mention various brands and sources for diesel engines but do not provide detailed specifications or confirm the performance characteristics of the suggested engines. The discussion reflects uncertainty regarding the exact requirements and definitions of "cheap" and "low power."
Individuals interested in small diesel engines for projects, particularly in academic or experimental contexts, may find the information relevant.
ecocarproject
what is the cheapest and low power diesel engine available at present? i am seeking 3 KW engine with of minimum weight available for my college project.
Diesel engines need a very exact fuel injector, to meter fuel to each cylinder for every combustion cycle.
That is expensive, so there is no really cheap small diesel sold anywhere, afaik.
There are portable multi fuel generators in service with the military, maybe you could find one from a surplus auction, but otherwise expect to see only bigger units. The smallest I've seen were whole house backup generators, around $10,000 for a 15 kw genset.
Here is a Subaru brand portable generator with 3300 watt output for about $3300.00
https://www.amazon.com/dp/B0035I1Y4U/?tag=pfamazon01-20
There are several diesel engine manufacturers (e.g. Hatz, Yanmar, Perkins, Deutz, etc.) which make small output diesel engines. Of course, the price of a portable generator includes the generator itself. If you contact an engine dealer, you can probably get info and prices for the size unit to suit your needs.
You can buy a 6hp diesel engine at amazoncom for about $500.
$300 on ebay
http://www.ebay.com/itm/R175N-Diesel-Engine-for-Generator-/230959474322?pt=LH_DefaultDomain_100&hash=item35c641e692&vxp=mtr
24K
