New Business- HELP Industrial Equipment and Electrical question
The discussion revolves around the challenges faced by a new business owner in setting up industrial electrical equipment, specifically a packing machine and a mixer, with specifications that differ from standard US electrical systems. The focus includes understanding voltage, phase requirements, and the need for proper electrical connections.
  • The original poster (OP) inquires about how to operate machines rated for 220v, 3 phase, 50Hz in the US, expressing uncertainty about compatibility and the need for an electrician.
  • Another participant questions the decision to order 50Hz machines for use in the US, implying potential issues with compatibility.
  • The OP later shares that the manufacturer clarified the specifications for the machines, stating that the first machine will operate at 230 volts, 3 phase, 60 Hz, and that the second machine requires 220v, 3 phase, 60Hz, but does not specify a plug type.
  • The OP expresses gratitude for the advice received from electricians on another forum, indicating reliance on community input for understanding electrical requirements.
  • A participant raises concerns about the OP's approach to setting up high-power machinery without professional guidance, suggesting the need for construction permits and inspections.
There is no consensus in the discussion. Participants express concern over the OP's reliance on forums for critical electrical setup information, while the OP seeks clarity on machine specifications and the necessary steps to ensure proper installation.
The discussion highlights the OP's lack of electrical knowledge and the potential risks involved in setting up industrial equipment without professional assistance. There are unresolved questions regarding the appropriate plugs and connections for the specified voltages.
This discussion may be useful for new business owners in similar situations, individuals seeking to understand industrial electrical equipment specifications, and those considering the implications of importing machinery with different electrical standards.
jcintron
Hi,
I am a new business that has ordered some electrical equipment.
The first is a packing machine and the plug that the machine is being sent I have attached to this post.
It is listed as 220v, 3 phase, 50hz but NEMA does not show this to be the same specifications.
How will I make this work in the US? Should I ask them to use something else? If yes, what?
I will be leasing a warehouse with high amps but as a non-electrically educated person I do not know how to proceed. I would definitely need an electrician. However, I want to ensure that I know what needs to be done.
I have a second machine that is a 1000L mixer. They are telling me the specifications for the output is: 3p AC380v 50HZ.
I asked for a picture of the plug as well. I don't yet have it but I would like to know what I must face once these machines arrive to my warehouse.
Please can someone give me suggestions as to what to do in this regard?
Welcome to the PF.
Why are you ordering 50Hz machines for use in the US?
Thankfully, I inquired with the manufacturer. This is the response: Machine 1. The motor of DP1000 will be 230 volt, 3 phase, 60 Hz based on the information.
No plug- direct connection.
Machine 2. Ok,the voltage you need is 220v,3phase,60hz. What plug should be used for this?
I am extremely glad I went on another forum and spoke with some electricians who recommended I write to the manufacturer and straighten out the issues with the crazy voltages and amps for the US. I am not educated in this field at all and I rely on public forums of those educated in this field to lend a hand.
Thanks anyhow.
You seriously are putting together an industrial plant with high power elecrical machinery, and are relying on web forums to tell you how to set it up? I hope you at least are planning on getting construction permits for this, and will have the work inspected and approved by your local building department inspectors.
Your comments are worrisome. This thread is closed as dangerous. You can PM me if this is not the case.
19K
  • · Replies 41 ·
