I don't understand Electric Potential in battery
The discussion centers on understanding electric potential in the context of a battery and conductors. Participants explore the nature of potential difference, the role of charges, and the implications of resistance in circuits, without reaching a consensus on the foundational concepts involved.
  • One participant presents the equation for electric potential due to a point charge and questions the location and polarity of the charge causing potential difference in a conductor.
  • Another participant notes that a battery operates differently from a point charge, suggesting a need for clarification on the role of batteries.
  • Several participants express confusion about how to understand potential difference when current flows from one point to another in a conductor, emphasizing the importance of charge presence at both ends.
  • One participant introduces the idea that potential difference could depend on energy produced by chemical reactions in batteries or other factors like magnetic fields.
  • Another participant discusses the relationship between resistance in the circuit and the maintenance of charge difference across a battery's terminals, noting that battery voltage may decrease with increased current.
  • A participant describes a scenario involving charged circular discs and a cylindrical conductor, seeking to understand how potential is calculated at each end to determine which is higher.
  • One participant mentions the concept of capacitance in relation to the charged discs and discusses the behavior of voltage when shorting the capacitor with a conductor.
Participants express various viewpoints and uncertainties regarding the nature of electric potential and potential difference, with no clear consensus reached on the foundational concepts or definitions involved.
Limitations include the lack of information about batteries and the dependence on definitions of potential and charge. The discussion does not resolve the mathematical or conceptual steps necessary to fully understand the potential difference in the described scenarios.
wirefree
I understand potential as follows:
V(r) = Q/(4*pi*e0*r)
If current flows from high potential to low potential in a conductor, I am keen to know where is the charge Q located that cause this potential difference across the two ends of the conductor. I would also like to know its polarity.
Thanks in advance.
Regards,
wirefree
The equation you have quoted gives the potential at a distance r from a point charge Q.
A battery is something completely different
Please allow me to rephrase:
If current flows across a conductor from A to B, then how can I understand the potential difference between the two end points?
NOTE: I am not given any information about batteries in this case.wirefree
The potential difference is because of the presence of charges at both ends of the conductor.
It's really not important just how big these charges are.
What is of interest is the potential difference which could depend on the amount of energy a chemical reaction in a battery produces per unit charge, or the strength of the magnetic field and the speed that a coil rotates in it.
There has to be some resitance in the circuit, either in the conductor or within the battery. Assuming the conductor has some amount of resistance, then a battery will maintain a charge difference between it's terminals that corresponds to the battery's rated voltage, depending on the amount of current being consumed. The voltage from most batteries will decrease somewhat as current increases, but for an idealized case, you can assume a battery's voltage is constant until the battery is depleted.
I have distilled my thoughts. Thanks for your inputs. Here's the question:
Lets slap two oppositely charge circular discs onto two ends of a cylindrical conductor. Clearly current flows. There is also a Potential Difference between the two ends.
It is this Potential Difference that I care to know more about in terms of the elementary definition, which is: work done on a charge by external force against an electric field.
Question: Since current (conventional) flows from higher potential to lower potential, I care to know how is it that the potential is calculated at either ends in order to determine which end is higher. (See first response above which discourages use of the point-charge formula.)
Regards,
wirefree
Ok so those circular discs have capacitance. Just before you short out the plates the voltage will be given by Vi = Q/C.
If you short out that charged capacitor with an ideal conductor the voltage will fall instantly to zero and the current will be infinite.
Real conductors have resistance. The voltage will fall according to...
V = Vi * e-(t/RC).
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capdis.html#c2
Thank you, CWatters.
  • · Replies 21 ·
  • · Replies 58 ·
