Magnetic Ferrofluid Valve
by MrSponge
Tags: ferrofluid, magnetic, valve
MrSponge
MrSponge is offline
#1
Apr18-13, 09:02 PM
P: 20
Hi,
I was wanting to insert 1 inch foam balls inside a container of ferrofluid, causing the foam ball to float.
A normal one-way water valve would not let the ball through without any leakage (I believe), therefore I think that If i can build a valvue that consists of a ring of neodynium magnets with the pole that repulzes the ferrofluid pointing towards the centre with the attractive pole hidden. Fitted at an angle pointing towards the ferroufluid and away from the feed tube of foam balls.
I belive that this valve with just over 1 inch in diametre would be sufficient enought to allow the foam ball through ( and break surface tension) and to be absorbed into the liquid which will then float up. Without allowing ferrofliud to flow into the feed pipe.
Thankyou and I hope this is clear
Phys.Org News Partner Engineering news on Phys.org
A smart prosthetic knee with in-vivo diagnoses
Old tires become material for new and improved roads
Students take clot-buster for a spin
Simon Bridge
Simon Bridge is offline
#2
Apr18-13, 09:57 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 11,070
Application?
... even if you had a perfect valve, you still have to push the ball into the fluid because you have to displace some fluid mass that would otherwise occupy the ball's immersed position.
What you describe appears to be a variation of this:
http://www.lhup.edu/~dsimanek/museum/unwork.htm#buoy4
berkeman
berkeman is offline
#3
Apr18-13, 10:00 PM
Mentor
berkeman's Avatar
P: 39,683
Quote Quote by MrSponge View Post
Hi,
Can you describe the application? Do you need to use ferrofluid? Or can you just use two different density liquids, and let the foam ball float up through the interface between them? If you need to use ferrofluid for some reason, can you just put a lighter fluid layer on top of it, and let the foam balls float up through the boundary between them?
Simon Bridge
#4
Apr18-13, 10:26 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 11,070
@berkman - the first link in post #2 shows you the application.
I'll edit it to be clearer - thanks.
Also see this related idea which was to use water.
Register to reply
Related Discussions
FerroFluid Experiment in Lab Classical Physics 2
ferrofluid travels in the direction of increasing magnetic flux General Physics 0
How to Make a Ferrofluid? General Physics 2
Question on Ferrofluid Biology, Chemistry & Other Homework 10
Ferrofluid synhesis... General Physics 2
