2Coins probability of Heads-tails in 40 tosses? HELP
  • Thread starter Thread starter aisha
    Probability
The discussion revolves around the probability of obtaining heads-tails or tails-heads when tossing two coins simultaneously, specifically over 40 tosses. Participants are exploring the calculation of this probability and its interpretation within the context of probability theory.
  • The original poster attempts to determine the probability of heads-tails or tails-heads appearing in multiple coin tosses, questioning how to show calculations. Some participants suggest that the probability might be 1/3 or 50%, while others discuss the implications of different coin types on the outcomes.
Participants are actively engaging with the problem, with some providing insights into the probability calculations and others seeking clarification on the methodology. There is a mix of interpretations regarding the probability values, and the discussion is ongoing without a clear consensus.
Some participants note that the problem is related to a biology lab context, indicating that the use of probability is intended to support understanding of Mendelian genetics, which may influence how the problem is approached.
aisha
2 coins are tossed at the same time There are 3 colums in a chart
1) Heads-Heads
2) Heads-Tails or Tails-Heads
3)Tails-Tails
the coins were tossed 40 times simultaneously.
What was the probability that heads-tails (or tails-heads) would appear? Show calculations.
(HINT: The probability of these two combinations must be added together because they were recorded together.)
Im thinking its 2/4 but not sure, and don't know what to show as calculations.
PLEASE HELP ME! :redface:
offtopic said:
(0_o) youve created 3 topics about this...you need to stop before you get banned, and to my observation this isn't the first time
but I am not so great with it either, but wouldn't it be 1/3 chance for all?
For your information all of my posts are different questions so mind your own business.
1) Heads-Heads
3)Tails-Tails
Yes, you're correct.
You have a 50% chance of coin 1 coming up heads. If coin 1 comes up heads, you have a 50% chance of coin 2 coming up heads. .5 * .5 gives you a 25% chance of both coins coming up heads.
If you do the same for each combination, you wind up with a 25% chance of each combination coming up. Since the coins are tossed simultaneously, you don't know if you have heads-tails or tails-heads. So you add the probabilities for both combinations together.
Unless, of course, you have two different coins (say a quarter and a loonie) and it matters which one is which. Then you would consider loonie-heads and quarter-tails as a different outcome from loonie-tails and quarter-heads, each with 25% probability.
can u show me what the calculation would look like BOB? I understand what your saying but not 100% sure.
If this pertains to statistics, you'll need to employ proper formulas and concepts to solve this equation, it may NOT be 1/2.
no this is not physics it was just a Bio lab using a little bit of probability to help understand mendel and the pea plant .
  • · Replies 57 ·
  • · Replies 25 ·
  • · Replies 126 ·
10K
