Finding the domain of this function
  • Thread starter Thread starter nothingsus
    Domain Function
The discussion revolves around finding the domain of the function 1/(sqrt(2x)-1)², specifically addressing the conditions under which the denominator is defined and non-zero.
  • Exploratory, Assumption checking
  • Participants discuss the implications of the denominator being zero and explore the conditions for the square root to be defined. Questions arise about the reasoning behind the constraints on x, particularly regarding the values that make the denominator greater than zero.
Participants are actively questioning the assumptions related to the domain, particularly the conditions under which the square root is valid and the denominator is non-zero. Some guidance has been offered regarding the implications of the square root's argument needing to be non-negative.
There is a noted concern about the values of x that lead to the denominator being zero or negative, and the discussion reflects on the implications of these conditions for determining the domain.
nothingsus
Find the domain of 1/(sqrt(2x)-1)2
Note: the minus one is not included under the square root
Title
So the denominator cannot be zero
so that means that sqrt(2x) cannot equal 1
x cannot be 1/2
letting the denominator be greater than 0 gets me x is greater than 1/2
my calculator says x is equal to or greater than 0 but cannot be 1/2
Where did the equal to greater than 0 part come from?
Title
x cannot be 1/2
From the square root. The argument of a square root can't be negative, so you need 2x ≥ 0.
Why are you concerned about the denominator being greater than zero?
The simplest way is, with the answer provided, plug in x=-1 and x=1/2 and you should know why.
  • · Replies 23 ·
