How to Fit Graphs and Text on the Same Page in LaTeX?
  • Context: LaTeX
  • Thread starter Thread starter lavster
    Graphs Latex
The discussion revolves around fitting graphs and text on the same page in LaTeX documents, addressing issues related to figure placement, spacing, and formatting. Participants explore various methods to achieve a desired layout while adhering to specific size and formatting requirements.
  • One participant notes that LaTeX automatically moves graphs to the next page due to space constraints and seeks a solution to fit text and graphs together.
  • Another suggests resizing images using the scale option in the \includegraphics command as one possible solution.
  • A different participant emphasizes that their graphs must remain a specific size and expresses concern about excessive vertical space between them.
  • One suggestion involves cropping images to reduce whitespace, using the trim option of the graphicx package.
  • Another participant proposes adjusting caption font sizes to accommodate the figures on the same page.
  • There is a suggestion to change the margins of the specific page to fit the figures better.
  • One participant mentions the importance of adhering to strict formatting rules for a hard copy submission, which limits their options.
  • Another participant questions the necessity of maintaining the current figure size and suggests that smaller figures may still be acceptable.
  • There is a mention of using the float package to force figures to appear in specific locations within the document.
Participants express a range of views on how to best fit graphs and text together, with no consensus on a single solution. Some participants propose resizing or adjusting margins, while others emphasize the need to maintain specific figure sizes.
Participants mention various LaTeX commands and packages, but there are unresolved issues regarding the specific parameters that control figure placement and spacing. The discussion reflects a variety of formatting constraints and personal requirements that influence the proposed solutions.
lavster
There was not enough room to fit my graphs in the text where they were supposed to go so latex put them in the next page. This meant that this page only has these two graphs and the text begins again on the page after that. There is a lot of space between (see attached). How do i make it take up less room and have text on that page too?
Thanks
Hi thanks for your response.
However my graphs have to be this size. and they don't go side by side unless smaller. Its the vertical space inbetween them I don't want. so instead of having 6cm between them on the page i want only one cm. if tried eg \vspace{-50mm} but that doesn't shift it.
Thanks
It could be that the images themselves have a lot of whitespace and need to be cropped.
If you put the \includegraphics command inside of \fbox, i.e.
Code:
\fbox{\includegraphics[options]{filename}}
it will draw a box around the figures and let you see if this is the case. If so, you can crop the image files manually, or (if you like trial/error) within your editor with the trim option of the graphicx package (example numbers):
Code:
\includegraphics[trim = 10mm 80mm 20mm 5mm, clip, width=3cm]{filename}
trim = l b r t (left bottom right top)
the graphics size is fine, and the white box is too. i have know idea why this is happening! :(
Sounds to me like you'll have to compromise on the size a bit and just adjust the caption font size so it's still readable. Play around with the scale and try to find the threshold where it allows the text on the same page.
You could also attempt to change the margin of THAT particular page to fit your figures.
By the way...why do you say your pictures HAVE to be that size? A bit smaller may not hurt and, for as long as you have imported your figures in pdf format, they should be nicely zoomable...remember, by now, most of us have pretty good monitors and will make the page pretty wide...so, at the end, the size of you picture does not matter that much.
ive got to give a hard copy... They have lots of rules incl fig size, margin size, font size etc etc :(
thanks ill have a play!
Well, the whole point of LaTeX is to meet publishing standards...if what they are asking you does not fit into the normal document, maybe they are not following publishing standards and all bets are off...you can go ahead and start modifying the page margin and all that stuff, as suggested before.
Did you try \vspace*{-50mm} ?
When you say "latex put them on the next page", do you mean each graph is inside
Code:
\begin{figure} ... \end{figure}
and the figures didn't end up where you hoped they would?
If so, try tweaking the parameters that LaTeX uses to control the page layout. The defaults are fairly conservative and won't put just a "few" lines of text on a page that contains mostly figures.
See http://mintaka.sdsu.edu/GF/bibliog/latex/floats.html, or google for more informatikon, now you know what the parameter names are.
You can use the float package with
Code:
\usepackage{float}
and then force figures to appear where you place them using
Code:
\begin{figure}[H]
    % figure stuff
\end{figure}
9K
  • · Replies 16 ·
