Radioactive decay - log question
The problem involves calculating the time it takes for cesium-137 to decay to 10% of its original amount, using the decay formula provided. The context is radioactive decay, specifically related to cesium-137 released during the Chernobyl disaster in 1986.
  • Mathematical reasoning, Problem interpretation
  • Participants discuss the manipulation of the decay formula and the application of logarithms to isolate the variable t. There is uncertainty expressed about the correctness of the steps taken, particularly in checking the work. One participant suggests a more straightforward approach using logarithmic properties.
Some participants have provided feedback on the calculations, indicating that the approach appears correct. There is a suggestion for a more efficient method involving logarithms, but no explicit consensus on the best approach has been reached.
Participants are working within the constraints of a homework assignment, which may limit the depth of exploration into alternative methods or solutions.
karmatic
The amount (A) of cesium-137 remaining after t years is given by
A=A[itex]_{0}[/itex]*2[itex]^{\frac{-t}{30.3}}[/itex]
where A[itex]_{0}[/itex] is the initial amount. In what year will the cesium-137 be 10% of that which was released at the Chernobyl disaster in 1986?
x[itex]^{\frac{m}{n}}[/itex]=(x[itex]^{\frac{1}{n}}[/itex])[itex]^{m}[/itex]
plug in my 0.1 on the LHS
0.1A[itex]_{0}[/itex]=A[itex]_{0}[/itex]*2[itex]^{\frac{-t}{30.3}}[/itex]
A[itex]_{0}[/itex] on both sides cancels out
0.1=2[itex]^{\frac{-t}{30.3}}[/itex]
convert decimal to a fraction
[itex]\frac{1}{10}[/itex]=2[itex]^{\frac{-t}{30.3}}[/itex]
take the reciprocal of the RHS to convert the negative power to a positive
[itex]\frac{1}{10}[/itex]=[itex]\frac{1}{2^{\frac{t}{30.3}}}[/itex]
take the reciprocal of both sides to remove the fractions
10=2[itex]^{\frac{t}{30.3}}[/itex]
isolate the variable t and calculate the remaining values
10=(2[itex]^{\frac{1}{30.3}}[/itex])[itex]^{t}[/itex]
10=1.02313981[itex]^{t}[/itex]
then this part I'm unsure if I'm doing right, and I'm not aware of how I should be trying to check my work
t=[itex]\frac{log 10}{log 1.02313981}[/itex]
t=100.6544213
1986+100=2086?
t=100.6544213
1986+100=2086?
That looks just fine to me.
thank you very much for the quick response, my mind has been put at ease :smile:
For future reference, there's a neater and less error-prone way to do the manipulation. Basically, we're using a rule of logs: ##\log a^b = b\log a##, where the logarithm can be to any base.
In this case, use common (base 10 logs) because one side is a power of 10 (actually, 10 itself). So:
$$10 = 2^{\frac{t}{30.3}}$$
Take common logs of both side:
$$1 = \log_{10}2^{\frac{t}{30.3}}$$
Use that rule mentioned above:
$$1 = {\frac{t}{30.3}}\log_{10}2$$
Rearrage:
$$t = \frac{30.3}{\log_{10}2} = 100.65$$
and so forth. The calculation can be done in one step right at the end. Most modern scientific calculators can immediately calculate base-10 logs (it's the button marked 'log').
